oil ports on turbo..
Okay, i know one side, the one with the threaded hole is for the line that goes from the oil sending unit from the block to the turbo right? and then.. the other side, which has a like a big square hole thing, is to the oil pan. correct? well, my question is, what do i connect to the sqaure side? i have a rev had kit, and it came with this flanged thing that i assume is what goes on there. Right now, the position of the oil return port is pointing straight up.. it's suppose to point down right? can i clock just that part down? because the compressor side is in the right direction, so is the other side.. thanks.
Re: oil ports on turbo.. (b18tdelsol)
All of the pieces of the turbo will spin when you loosen the screws. I've also got the revhard kit and used the red tube to run to the oil return line in the oil pan.
Re: oil ports on turbo.. (intekragsr)
Yeah man, that thick *** red hose.. so on the pan, i weld that like 2-3 inch pipe to the pan right? cuz i was looking at other peoples setups..they like tapped it..but i guess for us revhards..we use that pipe thing i guess. so that flanged should be pointing down right? on the turbo..?
