Need help. If I can move the pistons while they r in the block, is it bad?
I was checking my block out and noticed that I can move the pistons to side to side by pushing on them. Is it bad? Is there too much clearence?
Re: Need help. If I can move the pistons while they r in the block, is it bad? (TurboR)
No, that doesn't mean the block is bad. You are actually rocking the top of the piston which has a much smaller diameter than the skirt of the piston. If they didn't rock, you might be having ring-land problems from over heating the pistons. Depending on the type of piston, you should be able to slide a feeler guage of from .010-.015 into the gap.
Re: Need help. If I can move the pistons while they r in the block, is it bad? (earl)
EDITED: misinformation.
[Modified by 2K_TEG, 12:34 AM 5/17/2002]
Re: Need help. If I can move the pistons while they r in the block, is it bad? (2K_TEG)
WAIT, WAIT...That's at the skirt, not the top of the piston. It's much looser on top. You can't measure skirt clearance with the pistons and rings installed (unless thru the pan).
Earl
Earl
Earl
Earl
On my buddies turbo b18c (w/Ross pistons with the correct ring gap) rocked a little.. No biggie.
Ryhaz
10
01-14-2014 07:57 AM
Robban26
15
01-24-2004 01:31 AM
5thgencivic
11-29-2003 03:26 PM
