2.5 or 3 for FI?
Old May 17, 2002 | 07:03 PM
Pengo's Avatar
Default 2.5 or 3 for FI?
i kno alotta pple say that 3" piping is optimal for cars with turbo, but i was thinking, is 2.5 that bad? you'll still feel gains over stock rite? and will it be louder or quieter than the 3"? and will custom piping welded to universal muffler definitely be cheaper than buying a full catback? thanks
[Modified by Pengo, 11:03 PM 5/17/2002]
Old May 17, 2002 | 10:28 PM
FBP Ex-T's Avatar
Default Re: 2.5 or 3 for FI? (Pengo)
well i have a sohc vtec..and i went w/a 2.5 in greddy piping to an apexi dunk...if i were to have like a gsr turbo or si turbo i'd go w/3" unless u only want to run like 6-7 psi..then go w/2.5....i went w/2.5 cause im gonna be boosting less then 10 psi for now so its cool...
Old May 17, 2002 | 10:31 PM
degradated's Avatar
New User
In almost all cases, 3" will give you more power, and will also be louder.
Old May 17, 2002 | 11:53 PM
sushibug's Avatar
Default Re: 2.5 or 3 for FI? (degradated)
i'm contemplating the same thing. i really really want a quiet exhaust, as quiet as stock. but i dont think that is achievable with a 3" exhaust... unless the whole piping back is a straight-through 3" resonator?
Old May 18, 2002 | 01:09 AM
degradated's Avatar
New User
Default Re: 2.5 or 3 for FI? (sushibug)
Even then it still won't be as quiet as stock.
Old May 18, 2002 | 05:36 AM
TurboSedan's Avatar
New User
Nope, if you want all the power 3" gives you will sacrifice some noise level for that!
Old May 18, 2002 | 06:53 AM
csufweed's Avatar
Default Re: 2.5 or 3 for FI? (97CivicFerio)
3" all the way... the exhaust has plenty of restriction with that big turbo in the way, so by freeing up the exhaust as much as possible, you will get better flow. Also, the fact that on turbo cars, you dont utilized the scavenging effect and there is no exhaust pulse, there really is no need for any smaller sized diameter exhaust to promote scavenging. Noise level is lowered by the turbo due to the turbo restriction in the exhaust flow. The main reason why noise would be a concern is due to lack of sound deadening. I'm pretty sure that if you ran a pre-muffler in addition to the rear muffler, sound levels will be much lower. AND as long as there are not bottlenecks or louvers or other restrictors, you will retain just as much power as if you had a straight pipe... only factor would be the extra weight of another muffler, but that is really minimal.
Old May 18, 2002 | 06:58 AM
b18tdelsol's Avatar
Default Re: 2.5 or 3 for FI? (csufweed)
hey guys, whats the difference between mandrel bent piping and crush bent piping? i'm gonna get a custom 3" exhaust too, but the local muffler guy says he does crush bent..
Old May 18, 2002 | 07:04 AM
csufweed's Avatar
Default Re: 2.5 or 3 for FI? (b18tdelsol)
crush bent
they crush the steel to make bends. this causes turbulence, reduces diameter of piping, and in all reduces flow MAJORLY!
mandrel bent
smooth flow, smooth transitions, no turbulence caused. SUPERIOR!
Comparison of flow between a crush bent and mandrel bent - 3" crush bent is maybe equal to 2.25" mandrel bent in terms of flow. This does NOT factor in the turbulence caused by the crush bends.
Old May 18, 2002 | 07:06 AM
Ri5e's Avatar
crush bent sucks. If you look at a crush bent pipe, you will see ripples that cause exhaust flow disturbances. If you look at a mandrel bent pipe, the bend is smooth.
Old May 18, 2002 | 07:13 AM
b18tdelsol's Avatar
Default Re: 2.5 or 3 for FI? (BG Boost)
how much more is mandrel bends?
Old May 18, 2002 | 07:25 AM
TurboSohc's Avatar
3" mandrel bent is the way to go
Old May 18, 2002 | 07:58 AM
csufweed's Avatar
not much if anything... Click Here To Find A Good Shop
Old May 18, 2002 | 08:09 AM
B16C-RXed's Avatar
Default Re: 2.5 or 3 for FI? (TurboSohc)
This actually is a touchy subject, it also depends on the type/displacement of the engine...at least that's what some tech's told me...2.5' isn't gonna hurt...but definetly 3" if you want the car to breath...plus it does sound better, and if you really want it to sound stock, get a muffler with a silencer...Apexi has a model, I cant remember what it is, but with the silencer you can't hear anything...I had one on my old hatch, cause my girlfriend didn't like the sound of the exhaust...It might cause slight back pressure, but I'm sure it will run fine...just my .02 bro...good luck...
Old May 18, 2002 | 08:39 AM
E Swift's Avatar
Default Re: 2.5 or 3 for FI? (B16C-RXed)
For turbo, you don't want any back pressure. That hurts a turbo more then anything. And, with a turbo on a car, your exhaust will sound quiet anyways, unless you use straight piping and no muffler.
Get 3"
Old May 18, 2002 | 09:15 AM
B16C-RXed's Avatar
Default Re: 2.5 or 3 for FI? (E Swift)
Ohh, ok...yep just another motor guy over here, thanks for the info...but quiet??? I'm not totally sure on that...got anything to back that up with? The more air, the louder right???Vibration, etc.
Old May 18, 2002 | 09:59 AM
bigTom's Avatar
turbo's will make it quieter than an all motor car... but it still wont be quiet...
Old May 18, 2002 | 10:29 AM
Hammett's Avatar
Even with a small turbo like greddy for sohc? I thought 2.5 was good enough. Does anybody have a dynochart on 2.5 and 3 piping?
Old May 18, 2002 | 10:54 AM
Pengo's Avatar
Default Re: 2.5 or 3 for FI? (Hammett)
yea i was thinkin the same thing. except if u plan on running really high boost with a kit like the greddy, i figured 2.5 would be a good mix of power and sound cuz the greddy is made to work well with stock piping already. if nething i'd like to see a real comparison between 2.5 and 3
91crxturbo
May 13, 2007 06:32 PM
Blazeone
Jun 12, 2003 03:17 PM
Nine
Feb 25, 2003 05:10 PM
Rory Breaker
Dec 11, 2002 10:43 AM
turbogsr13z
Sep 27, 2002 12:26 PM
