Apex I AVCR Injector Duty Setting
1 Post
I have just finished my apexi avcr install. I am new to the world of boost and a lot of topics. First off, I dont understand injector duty. Also I do not understand how to set the duty on the avcr. Sorry if Im unknowlegeable, but would someone help explain this to me, and maybe simplify the steps to setting to the duty for my boost controller?
Everything is hooked up right on the install, but when I drove around with the boost controller off, my car sounded more muffled for some reason, even the blow off valve I tapped the side port of the wastegate to the intercooler piping also. When I had it tapped to the fpr vac line, it seemed to run a lot better.
Can you please leave your feedback? Thanks
Re: Apex I AVCR Injector Duty Setting (intekragsr)
All of the settings should be in the manual. A larger solenoid valve duty cycle will equal a higher boost spike. Your wastegate side port should be hooked to a boost source like your intake pipe. i've got the top port hooked to my avcr solenoid. No a question for your: Does your avcr display injector duty cycle? I hooked mine up and it won't display injector duty cycle.
