another plug gap question
Old May 14, 2002 | 04:02 PM
Aeka GSR's Avatar
New User
Default another plug gap question
for the life of me I cant get any shops in my area to order a 7 range plug.
so im stuck with the 6 range until i can order one online.
What gap should I be at on the NGK zfr6f-11 on a GSR turbo? stock internals.
Old May 14, 2002 | 04:04 PM
ekb18c's Avatar
Default Re: another plug gap question (Aeka GSR)
.30
Old May 14, 2002 | 04:07 PM
Aeka GSR's Avatar
New User
Default Re: another plug gap question (ekb18c)
wow i only thought that was for the 7 range. will that get too hot on a 6?
Old May 14, 2002 | 05:43 PM
5thgen's Avatar
I think summit racing sells most all ngk plugs. They can also one-day air or two-day air it.
Old May 14, 2002 | 06:52 PM
B20C5 Turbo's Avatar
New User
The gap isn't necessarily related to the heat range of the plug. Factors that dictate gap size are coil energy, lead type (wires), plug type (not heat), and cylinder pressures.
For stock internals with a stock distributor (assuming less than 11 psi) 0.30~0.32 should work fine.
Old May 15, 2002 | 05:05 AM
Dutchie's Avatar
I've had the same problem. I can't find 7's anywhere around here. I've been runnung 6's at .35 for awhile now and they're fine. BTW, I'm only running 5 psi.
josh's ep3
14
Jan 30, 2009 09:57 AM
acrocat
Acura TSX
Apr 18, 2008 01:04 PM
81CB900C
Aug 16, 2007 09:07 AM
projectwidow
Nov 21, 2006 06:33 PM
AsianMullet
Nov 8, 2003 10:46 PM
