oil blow by coming from breather filter
i have a k & n breather filter on my motor...but there's a little oil coming from it and it looks pretty dirty...so can i clean it or what are you guys doing to remedy this blow by from the valve cover situation? i'm also trying to avoid getting a catch can...i thought i read on this board that people were running a piece of hose directly under the car are something....maybe not
Re: oil blow by coming from breather filter (BG Boost)
it's just a piece of hose connected directly from the top of the valve cover(where a breather filter would go) straight down to the underneath of the car? now my question is...is this harming anything? of is it ok?
Re: oil blow by coming from breather filter (uneekcrx)
Depends on how much blow by you are getting. I was getting a huge amount of blow by and oil coming from my breather. But I had a bent rod and melted piston . But if you are only getting a bit of blow by you should be fine with just running a small tube from the breather down to the ground.
New User
Re: oil blow by coming from breather filter (TurboSohc)
I'm sure the EPA wouldn't like the tube coming off the vavle cover. I know when I used to run my car like that I would get the occasional burnt oil smell, besides that I had no problems with it.
Re: oil blow by coming from breather filter (SiRkid)
stays i beleive....then just pour it back into the motor periodically????
Re: oil blow by coming from breather filter (maxim)
i was just sayin.i knwo it stays in there..didnt know if ya pour it back in or not..i dont have one..so
bigstatik
07-18-2003 02:04 PM
