buying used ProfecB...
Old May 15, 2002 | 07:02 PM
SIK IN DA HED's Avatar
New User
Default buying used ProfecB...
i sold my profecB a few months ago and now i decided to use one again. i have a race coming up that i want to win, so i need to turn up the boost. i came across a used profecB. any suggestions on what i should look for to make sure its in good working condition?
Old May 15, 2002 | 07:11 PM
PrecisionH23a's Avatar
Default Re: buying used ProfecB... (dlplayboy)
make sure you ask the guy the thing works correctly, why he is selling it, and if he has had any problems with it. also, ask if all the parts come with it as well as the manual. buying used electronics is kind of sketchy... but if it comes from someone you know and youve seen it used, then you are pretty safe
Old May 15, 2002 | 09:53 PM
New User
Default Re: buying used ProfecB... (GudeH23a)
the thing is.. the only way is to install it i guess. just wondering if there was a better way to check. thats the thing about electronic boost controllers.
Old May 15, 2002 | 10:44 PM
DIRep972's Avatar
Smarter than you
I have the profec B now, I used to have a turbo XS manual.. I cant decide which one i like better.. the profec doesnt hold boost/spool up as quikly as the manual did, but It does allow me to adjust boost from inside the car.. I am thinking about going back to manual but I was having problems with boost spiking under quick load.. I dont know.. but yeh, buying a used profec shouldnt be a problem as long as it works, but if u only need to turn up the boost a manual would be much simpler to just throw on.
Old May 15, 2002 | 11:18 PM
New User
Default Re: buying used ProfecB... (DIRep972)
thanks DIREP972,
you pretty much cleared up a few thoughts in my head about whether or not i should get a turbo xs mbc just as i had planned when i sold my profecb. i figured the profecb made the turbo spool faster... because thats what i really want. i just dont want to get the boost spike thats comes with a mbc. i like being able to adjust boost inside the car though. hmmm.. decisions... decisions...
by the way, im gettin the profecB for 175.
Old May 16, 2002 | 03:47 AM
int3gra's Avatar
from where?
Old May 16, 2002 | 07:05 AM
sushibug's Avatar
Default Re: buying used ProfecB... (int3gra)
what about the dual stage turboxs manual boost controller? i think it switches off between each solenoid electronically... meaning in-car switch.
Old May 16, 2002 | 07:54 AM
b18b98's Avatar
is it an easy installation for the mbc like tapping it into a vac line and adjusting it?? sorry for being naive but i also want my turbo to spool faster and i'm deciding between the profec B and the turboxs mbc. TIA
Old May 16, 2002 | 08:06 AM
int3gra's Avatar
Default Re: buying used ProfecB... (b18b98)
Is the Profec A better than the B?
Old May 16, 2002 | 08:25 AM
DIRep972's Avatar
Smarter than you
yeh the manual was crazy simple. u just cut into a vacum line and put the BC inline. Im going to play around with the set up on my profec B a lil before I decide to go back though.
Old May 16, 2002 | 10:05 AM
New User
yeah, thats one thing i like about the mbc... its easy to install.
DIREP, when do you experience boost spiking or creep with the turbo xs? would you experience this if boostin 7lbs or less? or just at high boost? are you referring to the standard mbc or the hight performance bc?
Old May 16, 2002 | 10:40 AM
DIRep972's Avatar
Smarter than you
I never spiked with the standard MBC, but when I switched over to the "hp" version I started expierencing boost spike in 1st and 2nd off a 5k RPM drop.. it kinda sux because the way I had my boost set with the MBC I would hit .6bar off the punch, then through 3rd/4th boost would fall down to .5bar.. Now with profec Im only seeing .5bar off the punch but the boost slowly creeps to .6bar as I go through 3rd/4th.. i think i just need to play around with the settings though on the profec.
Old May 17, 2002 | 06:59 AM
New User
i figured the "hp" version was alot better to use because it uses the ball and spring design. doesnt that improve spooling? how did you like the standard compared to using the wastegate spring alone? was there any difference?
Old May 17, 2002 | 10:33 AM
DIRep972's Avatar
Smarter than you
yeh the HP version spools fast as hell, thats why im kinda dissapointed in the profec, its not spooling for **** compared to the manual.. but I think the ball and spring design is also the reason it used to spike.
Old May 17, 2002 | 10:53 AM
4dGSR at work's Avatar
i have a profec b for sale....used about three months
i was advised to use a manual boost controller w/ my standalone so i will not used the profec b in my miata.
It worked fine.
the only thing is that you need to set boost levels in gear (lil weird but it is like that w/ all of them from what i know. I never had issues
97elitehonda
May 28, 2007 10:34 AM
SpoolnByYou
Feb 22, 2006 05:33 AM
s2kkid
Nov 6, 2005 11:02 AM
TheIntegraGuy
Aug 21, 2002 10:53 AM
DIRep972
Nov 29, 2001 11:51 AM
