Vortech FMU
Old May 15, 2002 | 08:30 PM
Sohc Driver's Avatar
Default Vortech FMU
Hi can everyone tell me about the Vortech FMU...can you tell me what it does besides that it is fuel management..does it control spark etc...can you tell me all what it does....
Khoi
Old May 15, 2002 | 08:46 PM
echo999's Avatar
New User
Default Re: Vortech FMU (Sohc Driver)
Nothing but holding fuel pressure.
Old May 15, 2002 | 08:50 PM
samus143's Avatar
thats it, I thougt i would do more than that, like the greddy blue box which controls fuel flow and stuff.
Old May 15, 2002 | 08:58 PM
Default Re: Vortech FMU (samus143)
i thought the same thing too..that it would do more..like similar to the greddy blue box...
Khoi
Old May 15, 2002 | 09:06 PM
inspyral's Avatar
It increases fuel pressure relative to boost.
ex: the 12:1 unit raises fuel pressure 12lbs for ever 1lb of boost.
Old May 16, 2002 | 06:45 AM
Default Re: Vortech FMU (inspyral)
so is there even a need for a fuel controller with the FMU??
Khoi
Old May 16, 2002 | 07:18 AM
b18b98's Avatar
you'll need a fuel controller when your using 310cc injetors or higher
Old May 16, 2002 | 10:35 AM
inspyral's Avatar
Khoi
The FMU may cause you to run overly rich under boost, in which case you'd need a way to trim fuel(fuel controller).
Old May 16, 2002 | 11:32 AM
spooler's Avatar
You should consider using the SFMU b/c it is adjustable and will give you much better tuning parameters. BEGI also makes a rising rate AFPR that works very well.
hatchboy13
Jun 3, 2005 10:26 AM
Hyaboosta
Oct 8, 2004 12:10 PM
freeplay
Oct 10, 2003 09:30 PM
RNPoo7
May 7, 2003 03:24 PM
