im about to replace the rings ,suggestions ?
Old May 18, 2002 | 02:17 AM
Cyber ITR's Avatar
Default im about to replace the rings ,suggestions ?
rings are f*cked and i cant afford for forgies , so im just gonna replace the rings and put thicker headgasket
my question is what sort of rings shud i get ??
can i use 81mm JE rings on stock honda pistons ?
thanks
[Modified by VTEC_SiR, 11:20 AM 5/18/2002]
Old May 18, 2002 | 02:28 AM
VaporTrail's Avatar
New User
Default Re: im about to replace the rings ,suggestions ? (VTEC_SiR)
honestly, OEM rings should be more than fine. It's the OEM piston ring lands that are the problem, which are apart of the piston itself. Just use OEM, do a good hone job, and break it in properly, you should be set.
Blake St.romain
Aug 26, 2018 08:34 PM
turbo boost
Oct 27, 2014 11:09 PM
hondachris1994
23
Feb 9, 2009 07:55 PM
rudebwoy
May 28, 2007 02:03 AM
quik1
Jun 19, 2004 06:33 PM
