Turbo mounting question.........
Old May 16, 2002 | 08:20 AM
89civic1.8T's Avatar
Default Turbo mounting question.........
I was wondering if it would be ok to mount a turbo at an angle to help the dp clear? This would be on an angle with the ground so the compressor would be above the turbine slighly. (30-40 degree's). Would there be any problems with the oil delivery to the bearings? I would think it would be ok since it is under pressure. How about the return? We are trying to fit a large T3 on my friends Saab and if it was mounted at an angle that would help us out alot!
Old May 16, 2002 | 09:00 AM
BROOD's Avatar
Default Re: Turbo mounting question......... (89civic1.8T)
I hope someone else will back me up here but........
I would think there would be substantial problems with getting proper oil flow to the bearing assembly. Every turbo I have seen (twin BMW's, twin M-Benz's, RX-7, large diesel truck engines, etc.) have all had the turbo shaft at a horizontal position. The engine oil is under pressure but only a small amount of it makes it to the turbo, so proper drainback is very dependent on gravity and minimal restrictions.
SLPR.....
Old May 16, 2002 | 01:30 PM
Default Re: Turbo mounting question......... (SLPR)
My turbo see's 20-35 psi of oil pressure. Thats a bit of oil pressure to be affected by gravitey. I agree with you that I have never seen a turbo mounted with it's shaft not horizontal.
Old May 16, 2002 | 03:22 PM
Ben Huynh's Avatar
You can clock the turbo anyway you like but just make sure the center section is perpendicular(sp?) with the ground.
Old May 16, 2002 | 05:25 PM
Flamenco-T's Avatar
Default Re: Turbo mounting question......... (ben@importparts.com)
yes, otherise you'll have an blown oil seals not too mention oil leaks off of the oil return flange
Old May 17, 2002 | 04:12 AM
BROOD's Avatar
Ben, do you mean parallel? You are saying that the compressor housing can be rotated around; but the turbo shaft needs to be flat across the horizon, right? By the way, my last order came in. Thanks again, you guys are great. ~Jamie
My turbo see's 20-35 psi of oil pressure. Thats a bit of oil pressure to be affected by gravity. I agree with you that I have never seen a turbo mounted with it's shaft not horizontal.
89civic1.8T, actually I did see a picture last night of a turbo manifold (donno the engine) with the turbo appearing titled off parallel. It was only very slightly though. But then again it could have been the angle of the picture taken. And I could be wrong but isn't 20-35 psi a little too much oil pressure to see at the center section?
Anyone else have any input? I'm trying not to confuse myself more than usual.
Old May 17, 2002 | 07:24 PM
Ben Huynh's Avatar
Jamie, you just have to have the oil feed port pointing up and the oil drain pointing down. Glad to hear you're happy with your last order.
Old May 18, 2002 | 11:50 AM
My turbo was seening 60-70 psi+ before a put a needle valve inline to turn the pressure down to a max of 20-30. I ran a greddy turbo with the stock oil pressure and it was fine for 3 years. What about drag kits/fmax/custom kits? How do they turn there pressure down going to the turbo?
Old May 20, 2002 | 11:19 AM
BROOD's Avatar
OK I see you were talking about the oil feed port and oil return ports being perpendicular to the ground. (oil feed port pointing up and the oil drain pointing down) I was thinking you ment the turbo shaft orientation instead. My bad.
2x0
Oct 26, 2018 06:42 PM
Bigrederic
Apr 29, 2010 06:18 AM
slowteg550
Jul 11, 2006 02:57 PM
o'malley_808
Sep 2, 2005 06:11 AM
jdmcivic1999
Feb 12, 2005 04:05 PM
