Oil pressure guage question
Old May 17, 2002 | 10:14 AM
JMinSi2000's Avatar
Default Oil pressure guage question
I've got an autometer electric oil pressure guage. Do I keep my stock oil pressure sender and the guage sender or do I just replace it with the sensor thing the guage came with?
Old May 17, 2002 | 10:44 AM
BDTURBO's Avatar
Default Re: Oil pressure guage question (JMinSi2000)
You have to take the stock one off but Im in the same boat, how the hell do u get it off? Honda said they would do it for $65,
Old May 17, 2002 | 10:50 AM
JMinSi2000's Avatar
Default Re: Oil pressure guage question (BDTURBO)
I've read that you have to keep the stock one on there to trick the ecu or something, but i've also heard different.
Old May 17, 2002 | 02:45 PM
DA666's Avatar
keep tthe stock one and remove it.....then get a 3 way 1/8 npt fitting from home depot or sumwhere....teflon tape em all ttogether.....get a 1" npt barb to screw into the block and reconnect everything.....
a better safe way to do tthhis is endyn's idea(whhich i use and feel comfortable about, due to 4 cyl vibration) is at http://www.theoldone.com under articles....
just to help ya out.....whhen u see itu will understand....
i foget what size mm socket it is.....maybe 19mm? somewheres around thhere....
Old May 17, 2002 | 09:28 PM
JMinSi2000's Avatar
Default Re: Oil pressure guage question (T3T4DA6)
Keep the stock one and remove it? Whats that supposed to mean? I've got both of them in there now and it seems to be working. 25psi at idle and around 65-70 when i'm driving around.
Old May 20, 2002 | 12:43 PM
Hybrid's Avatar
Well how do you think the ECU see's oil pressure?
I've had some oil problems as of late but plan on getting ride of them once and for all.
Going to run braided hose from the oil feed at the back of the block to an air manifold on my strut tower or firewall. From there I can send another braided line to the turbo and have several holes left in the manifold for my oil pressure gauge and oil pressure sender.
Then if there are any problems, chances are you won't have ot get under the car to try and fiddle with the darm T's on the back of the block. Doing it this way I don't anticipate any future leaks.
Old May 20, 2002 | 12:53 PM
CovertFI's Avatar
Default Re: Oil pressure guage question (Hybrid)
y cant you hook the gauge up to the stock sensor? and dont use teflon tape it will leak
Old May 20, 2002 | 01:16 PM
Xerxes's Avatar
New User
Default Re: Oil pressure guage question (CovertFI)
do this, trust me
Old May 20, 2002 | 01:19 PM
apexii's Avatar
The sender on the electric gauge is different.
For the record, I had my 'dummy light' sender removed for a good year with no problems. This was before and after going FI. I was under the impression that all that is, is an 'you're out of oil' reminder, not a functional gauge.
I had both hooked up, but then removed the oem one. I then removed the autometer and worked fine without any gauge.
Does vtec need oil pressure to activate, yes. Does it read it from that sender? no.
Old May 20, 2002 | 01:33 PM
paulzy's Avatar
Default Re: Oil pressure guage question (apexii)
If I remember correctly, it waas a 27mm socket
Old May 20, 2002 | 01:46 PM
CovertFI's Avatar
did not know that (about the vtec), so how does it know when you are low?
itr1244
Sep 23, 2009 04:18 PM
chitownrida
Jan 25, 2006 01:55 PM
mattssi
Sep 29, 2004 09:55 PM
Juccord
Jul 11, 2004 07:41 AM
Petah
19
May 6, 2002 05:41 AM
