Clutchnet Stage 2 Clutch ????'s
My friends and I just installed this clutch on my teg. My questions are: Has anyone else felt that the clutch is easier to push in than stock??? OR That it chatters like a ****, if you try to slip it when taking off?? I realize that it is 6 puc and that it will chatter, but it is shaking the car when I take off. Would you say that this is more driver error than anything?, or could it be a problem with the clutch? Any help would be great...Thanks.
Re: Clutchnet Stage 2 Clutch ????'s (Jamison)
u'll get used to it... to me... what u described is normal... i had a cm stage 4 and an act stage 3... both clutches chattered and made noises during engagement... not to mention shaking the whole car
Re: Clutchnet Stage 2 Clutch ????'s (ek9t)
dont worry man i have the same one. did you install a diffrent flywheel by any chance?well my stage 2 is great i sold my act just to buy a clutchnet. its much better to drive and grips like a ****
New User
Re: Clutchnet Stage 2 Clutch ????'s (turboex)
it seems normal to me. you just have to get used to it. just gas it alittle more than u usually do with the stock clutch. it wont shake, hop, or chatter as much that way.
Re: Clutchnet Stage 2 Clutch ????'s (dlplayboy)
yep, I got a clutchnet stage II w/ 7.5 lb flywheel and I'm finally getting pretty good at it!! It just takes a while.
Re: Clutchnet Stage 2 Clutch ????'s (jamal-188)
damn i got stock and i engage it soo low sometimes that with my motor mount inserts the car shakes like crazy.i cant wait for a beefier clutch
Ben Huynh
06-17-2001 01:16 PM
