Turbo.. What do i need !!?
Old May 16, 2002 | 04:25 PM
Zeus Zore's Avatar
Default Turbo.. What do i need !!?
What would i need 2 put a turbo on my car !?! turbo/pips/hoses/wires/ ??? what parts do i need !?
it is a D15B
could i lower comp with 2 head gasket ?? or whats the best way !?
will the engine hold up for aound 0,4 BAR ?!?! or is it really needed for new pistons and rods ????
THX !! any other thing when dealin with turbos are welcome !!
Old May 16, 2002 | 05:02 PM
AlphaKennyWun's Avatar
Default Re: Turbo.. What do i need !!? (Zeus Zore)
whats a turbo?
Old May 16, 2002 | 05:24 PM
sushibug's Avatar
http://coolazz.tripod.com/turbo.html
Old May 16, 2002 | 05:51 PM
Zeus Zore's Avatar
Default Re: Turbo.. What do i need !!? (sushibug)
SUSHI !! ;-) but still wanna know about this :1994 Honda Civic Si d16z6 1.8L turbocharged: ... ? D16 1.8 !?!?
Old May 16, 2002 | 06:20 PM
Zeus Zore's Avatar
What does the wastegate do ?? and where does it connetct ??
Old May 16, 2002 | 07:20 PM
rjardy's Avatar
waste gate monitors how much boost the turbo puts into the intake tract by bleeding off excess exhaust. it connects usually on the exhaust manifold before the turbo. or there are allso internal wastegates that are mounted to the turbo itself.
hth
ROB
Old May 16, 2002 | 07:26 PM
Zeus Zore's Avatar
Default Re: Turbo.. What do i need !!? (rjardy)
i thougt that it was the blow of valve that did that .. ??!?!
Downpipe = ??? where does this go !?!? exhaust or filter ??
Old May 16, 2002 | 07:27 PM
BlueShadow's Avatar
the blow off valve bleeds air to the atmosphere whenever the throttle plates closes, this prevents damage to the compressor and keeps the compressor fan blades from "stalling". the BOV i located in the intake pipe right before the intake manifold.
EDIT: an the down pipe is underneath the car, right in front of the catalytic converter. It's part o the exhaust system.
[Modified by BlueShadow, 4:29 AM 5/17/2002]
Old May 16, 2002 | 07:35 PM
Ltech's Avatar
Here is the basic
http://ask.com/main/metaAnswer.asp?t...t=020516232818
You need to buy the Maximum Boost book. This is a good book.
projectPSI
Jul 20, 2004 08:54 PM
cr-x si
Feb 6, 2003 04:51 PM
GSRacer
Jan 2, 2002 01:04 PM
GruvyTune
Dec 2, 2001 04:32 PM
