What to do immediately when engine overheats?
Old May 16, 2002 | 09:56 PM
austrian type-R's Avatar
Default What to do immediately when engine overheats?
Shut off the engine, I think it is not a good idea, cause the coolant circualtion is off. --> engine gets more hooter
Driving about 50 mhp to get enough wind thru the front mount coolers? I guess
When available, spraying lots of water on the front mount intercooler & radiator while the car is idling, I think x2
Any other good ideas when this happen?
Old May 16, 2002 | 10:03 PM
Turdblow rex's Avatar
Default Re: What to do immediately when engine overheats? (austrian type-R)
DOOD!, your engine has hooters? she must be one hot engine!
Old May 16, 2002 | 10:10 PM
Prelude Vtec 23's Avatar
Put your heat on full blast. Works great, my friend's hatch used to overheat alot, when you put his heat on full blast you could literaly see the gauge go down.
Old May 16, 2002 | 10:25 PM
Default Re: What to do immediately when engine overheats? (Prelude Vtec 23)
HAHAAHA, that was actualy a typo!!
What do you mean with full blast? Drive as fast as possible to bring the temp down?
Old May 16, 2002 | 10:32 PM
Rain_man's Avatar
New User
Turn your temp slider to maximum heat (all the way to the left) and turn on the fans to 4.
Old May 16, 2002 | 10:41 PM
sgT's Avatar
sgT
If you are overheating and you drive faster the engine WILL NOT cool down, it
will just get hotter. And pouring water on anything isnt gonna help either.
Turn the heat on full and if that doesnt work, then shut the engine off before
the head warps.
Old May 16, 2002 | 10:58 PM
blkDOHCsol's Avatar
New User
Default Re: What to do immediately when engine overheats? (sgT)
If I overheat at idle, and I mean like long *** drive thru idle...only then that damn taco bell at 11:30 my gague gets like almost H...other than that im always like 2 bars from C...head gasket?
I thought on driving about 70mph, cause the gas pedal must only be diped to hold that spead and the engine is not under load. Turning the engine off is bad, cause I saw it on a turbo diesel (we pulled a trailer with 700kg and this car had only 75hp on a 35 deg C hot day always on WOT) when we turned the engine off on the gas station the coolant temp gone very high up. I started the car and it went back.
Old May 16, 2002 | 10:59 PM
sgT's Avatar
sgT
Well, sometimes even idling the car wont bring the temps down, you have no choice.
Old May 16, 2002 | 11:15 PM
paulzy's Avatar
usually turning the heat on to high on fresh works...but if you're like me and bypassed the heater core, then you're fucked...
any suggestions for that?
Old May 16, 2002 | 11:28 PM
Default Re: What to do immediately when engine overheats? (Slow_ass_4dr)
mount a 2nd radiator elsewhere and mount a switch inside the cockpit to activate it when you use em.
[Modified by austrian type-R, 9:28 AM 5/17/2002]
Old May 17, 2002 | 05:50 AM
TheSwift1's Avatar
Best cure? don't allow it to happen...
upgrade ur cooling system...
Old May 17, 2002 | 07:33 AM
boostedhb's Avatar
Default Re: What to do immediately when engine overheats? (blkDOHCsol)
definately sounds like a blown headgasket.
Old May 17, 2002 | 07:49 AM
88CRXHybrid's Avatar
Default Re: What to do immediately when engine overheats? (boostedhb)
one thing most of you have forgotten to mention about the heater trick. You MUST be sucking the air from outside the car. If you have the heater on circulate, pulling from the inside of the car, all you get is sweaty driver.
Old May 17, 2002 | 08:15 AM
Liltrix's Avatar
Same here, when I first built my coupe, the radiator was not wired up properly and it started to overheat so I turned the heat on full blast and it cooled the engine almost instantly.
Old May 17, 2002 | 08:24 AM
bigTom's Avatar
Default Re: What to do immediately when engine overheats? (Liltrix)
aluminum radiator with an electrical water pump... problems solved... and if u do overheat... u can shut the motor off and leave the water pump and fan running for a little bit
Old May 17, 2002 | 08:39 AM
D-Man's Avatar
na,sounds like either his fan isnt working right or his radiator is either too small or its old and getting clogged
Old May 17, 2002 | 09:53 AM
X2BOARD's Avatar
Dude, like, duh... just get a supercharger !
You will have a blower on the motor at all times and that means you will never be able to overheat ! Your new supercharger will be constantly blowing your motor, so your motor will be blown and won't ever overheat. Not to mention, you can get UPGRADED pulleys for your supercharger, so you would have pulleys too !!!
I don't get it tho ? Put the HEATER on ? It'll just make the car HOTTER ! I mean, like, everytime I put on my heater, I feel too hot, especially since I'm in Florida, and in Florida it gets hot and I like to be cool.
Old May 17, 2002 | 10:52 AM
PrecisionH23a's Avatar
Default Re: What to do immediately when engine overheats? (X2BOARD)
please tell me you are kidding.... and yes, turning the heater on does help to emmit heat. what you need to do is check your coolant fluid for traces of oil or carbon monoxide gas. if you find either of these, then its your headgasket or you might have messed up some of your internals, such as melted a piston, damaged your sleeves, warped your head, etc etc. but start with the easy things first, such as a new thermostat, bleed your coolant lines, and find out if your fans are operating correctly or not. if you are parked and your car is overheating, it sounds like your fans are not kicking in properly. if you are getting on it and your car is overheating, then it is probably some internal damage that occured. good luck
Old May 17, 2002 | 11:09 AM
X2BOARD's Avatar
Default Re: What to do immediately when engine overheats? (GudeH23a)
Why ? What wrong with wanting a cooler engine ? Pfffftt.... I can't wait to get me a supercharger, then I won't need an intercooler anymore ! YAY !
Old May 17, 2002 | 11:23 AM
technine's Avatar
That sounds more like no fan blowing to me. If you even think it is a blown headgasket you should defenitly check your radiator for oil and discoloration and check your oil too.
Old May 17, 2002 | 01:38 PM
CovertFI's Avatar
check your coolant for carbon monoxide gas? you mean the gas that is colorless and ordor less? are you sure your name is not super man?
Old May 17, 2002 | 01:50 PM
Default Re: What to do immediately when engine overheats? (CovertFI)
yeah that gas. I think you check it with a special tool. You suck up some coolant in a tube with these ***** in it. If the ***** float or sink tells you whether you need to change out the fluid or not AKA carbon monoxides in the coolant or not.
Old May 17, 2002 | 01:56 PM
CovertFI's Avatar
Default Re: What to do immediately when engine overheats? (88CRXHybrid)
ahhh i see said the blind man
Old May 17, 2002 | 02:51 PM
dustin's Avatar
How can the motor get hotter when the engine is turned off ?
Heat = thermal energy. Turn the motor off and the temperature will go down.
