got oil cooler....now what? :(
well,
i got the oppurtunity to jump onto an oil cooler, it was used 5 days, and the engine it was on blew, so i got it free, yes brand new. with SS inlet and outlet lines. even has a mini 3" fan that i can mount to the front with a toggle switch to cool it down even more.
my question is, well basically im lost, where do i tap for the inlet and outlet? how do i get the oil to the cooler, and return it back to the original "cycle"
i know, its a stupid question, but i dont know?
Re: got oil cooler....now what? :( (NYb16)
i think u need a sandwich plate adapter that goes in between the block and oil filter...the adapter should have 2 ports for u to connect the oil cooler lines
Re: got oil cooler....now what? :( (Quaalude)
thats the only way i know of doing it....wel maybe you can run it off your turbo oil feed line........but it might take a little longer to get the oil to the turbo on initial startup, but i dont know. i would go wioth the plate like quaalude said.hth
ROB
your going to need this if you dont already have right one. http://permacool.com/Catalog/Cat_page28.html
or this
http://permacool.com/Catalog/Cat_page29.html
but then your goin to need a remote filter mount also if you use the spin on adaptor
http://permacool.com/Catalog/Cat_page30.html
i would get the sandwitch because its more conveient
late
[Modified by lamchop0000, 9:58 AM 5/18/2002]
or this
late
Re: got oil cooler....now what? :( (lamchop0000)
http://www.racerpartswholesale.com
I just ordered one from this place. Pretty cheap at around 24.00. They are on the East coast somewhere. Should get to you quickly.
big-cat
06-15-2007 03:53 AM
