open or closed loop
Old May 15, 2002 | 08:10 AM
RCSIVTEC's Avatar
Default open or closed loop
i understand that with a closed loop exhaust its much quiter than open loop. i know that the power lost in low boost is about 10-15hp but how much power is lost at 25-27 psi. or is it just better to use a lawnmower muffler on the dupetube.
[Modified by RCSIVTEC, 12:11 PM 5/15/2002]
Old May 15, 2002 | 10:21 AM
HXMan's Avatar
Default Re: open or closed loop (RCSIVTEC)
My guess is that if you are running that much boost, you are going to be loosing LOTS of power. Are you going to have a street car running that much boost? Asking, cuz it seems the only honda turbos running that much are track cars and who cares how much noise they make!!
Old May 15, 2002 | 11:29 AM
Etylorcen's Avatar
Default Re: open or closed loop (HXMan)
Yeah if its a track car (which I doubt) then who cares about the sound. The only sound that should matter is you screaming when you get your fast *** time slip hehe. If you actually plan to run that much boost...which is pretty insane then just keep it open look. But properly closed look systems don't loose that much power over open loops systems and they are quiet w/o that rasping wastegate dumping sound.
Old May 15, 2002 | 01:06 PM
RCSIVTEC's Avatar
well for the street i will only be running about 15psi and when i hit the street races i will crank it up to 27 psi.
Old May 15, 2002 | 01:10 PM
RCSIVTEC's Avatar
Default Re: open or closed loop (Etylorcen)
its going to be for both the track and the street when i am just crusing i will keep it at 15psi now when run then i will crank it up to 27psi. its insane boost but you never know what the other person might have better safe than sorry.
boofunit
Sep 3, 2011 12:12 PM
93GS-TypeR
May 15, 2008 06:52 AM
Spec R_GSR
Aug 22, 2006 09:05 AM
bgod
Aug 13, 2001 09:43 PM
