Engine Work With Turbo
Old May 15, 2002 | 06:09 AM
cyberx's Avatar
Default Engine Work With Turbo
Engine Work for Turbo
ok i was wondering exactly what is a really good setup to run Turbo on a Stock 90-91 CRX Si engine d16a i wanna know everything from head work to block work, i wanna run low 13s to 12s, and i am willing to spend 10,000 dollars on doing so.. but i wanna know exactly what to do, i don't want to put 10,000 dollars into waste..... also i have a question, is it true that you dont want to port and polish your head for turbo, i heard you just want to Port your head, thats what Extreme Motorsports from NJ claims, but i dont know if its true, i know you shouldnt port and polish your intake manifold, anyways, help is appreciated....
Old May 15, 2002 | 08:44 AM
Dutchie's Avatar
Default Re: Engine Work With Turbo (cyberx)
Have you considered a swap? Any B series motor with a drag kit at 8 psi should give you those numbers without building the motor. Probably cheaper then building the D16.
Old May 15, 2002 | 09:13 AM
cyberx's Avatar
Default Re: Engine Work With Turbo (Dutchie)
Yes i have thought of that, but my brother has a B16 in his CRX and hes working it to death, and plus i want to be diffrent everybody that hooks up their CRX drops a new engine in their, and think their running low 14s, when in fact their just running 15s, i dont believe in spending around 3-4 Gs on an engine tranny and mounts linkage, and all those extra parts that i would need and would most likely go with like Intake Headers and Exhaust when i do the swap, when i can just spend 4 Gs on a Turbo and 5-6 G's on engine work and have my car running faster then people who spend 4 Gs putting an engine on, and turboing it stock at about 8 lbs only running 13's with the turbo if that....... and plus it is more fun having a little engine turbod, and i believe id get more respect from it.... thanks...
titi_vtec
12
Nov 3, 2012 05:34 PM
turboda4dr
Dec 24, 2007 03:45 AM
illogic65
Aug 26, 2004 11:00 AM
Fly By Ya
Oct 4, 2002 04:27 AM
cyberx
May 16, 2002 07:43 AM
