No downpipe...lots of smoke normal?
Old May 14, 2002 | 08:50 PM
OKSolSi's Avatar
Default No downpipe...lots of smoke normal?
I finally got everything working - no leaks - no problems, so far. (*I do not have a downpipe made yet) I haven't taken it for a drive yet because I'm running stock injectors. When I started it up at idle it was fine, no smoke, then when I rev'd it to about 2500 a few times, I was busy watching my tach and when I looked up, quite a bit of white smoke was emitting from my bay. I'm assuming this came from my turbo manifold because I have no downpipe and its raw exhaust? When I killed the car to get out and take a look, it was rising up through my entire engine bay so I couldn't tell its point of origin. Is it normal for a setup without a downpipe to puff white smoke? Could it be because I'm running too lean or an oil problem?
Old May 14, 2002 | 10:17 PM
Ri5e's Avatar
Default Re: No downpipe...lots of smoke normal? (OKSolSi)
Probably spitting out a lot of fuel.
No Primary O2 sensor....
Old May 15, 2002 | 03:02 AM
inspyral's Avatar
Default Re: No downpipe...lots of smoke normal? (BG Boost)
Is the turbo new? Might just be spitting out some residue from assembly.
Old May 15, 2002 | 05:08 AM
CovertFI's Avatar
Default Re: No downpipe...lots of smoke normal? (inspyral)
what i did with my test run. i attached the o2 sensor to the outlet of the turbo with a coat hanger. lol
it worked!
Old May 15, 2002 | 05:55 AM
Finest's Avatar
Default Re: No downpipe...lots of smoke normal? (CovertFI)
I'm pretty sure it's just residue burning off. Give it about 10-15 mins of light driving and it "SHOULD" be gone. Double check all gaskets and oil line fittings.
Old May 16, 2002 | 08:52 AM
OKSolSi's Avatar
Default Re: No downpipe...lots of smoke normal? (Prelude_RCR)
OK well it still smokes like a ************ off and on. Sometimes it stops and doesn't do it at all until I stop somewhere and leave the car off, then when I come back and start it, it will smoke for like 5 mins then stop. No oil is in my intake pipe, and all the smoke is coming out of the downpipe outlet (I dont have my downpipe on yet). I think maybe there is some internal leakage inside the turbo housing? Is this anything I can look at myself without ruining the turbo?
Old May 16, 2002 | 08:55 AM
OKSolSi's Avatar
Also, I think maybe my return line is too small. It is the same size as my inlet line which I think is 1/2 inch in diameter. Is that a bad size? Should I make the oil pan's inlet nipple bigger also? It's smaller than 1/2 inch. Typing that out, it sounds retarded, so I guess I will go get that fixed.
Old May 16, 2002 | 11:12 AM
ludelvr's Avatar
from my understanding, the oil drain should be a lot bigger than the oil feed. One of the main reasons is that the oil feed is pressurized where as the oil drain works off of gravity. If u don't have a sufficient diameter for the oil to drain, then the potential for the oil to get backed up into the turbo and leak past the seals becomes more likely.
eg9d16turbo
32
Dec 14, 2010 07:33 AM
standbackimapro
11
Jun 24, 2007 01:08 PM
bumthology
13
Jul 29, 2005 09:46 PM
johnisenglish
Jan 9, 2003 09:32 PM
inline976
Aug 30, 2002 01:43 PM
