need pics of check valves
Old May 14, 2002 | 07:47 AM
Coldsi's Avatar
Default need pics of check valves
I took off the map sensor and tried to shove a tee into the hole but there's a metal dish in the way, does this come out? I shoved a tee into the hole and tried the check valves, but my cars idles like **** with one valve and won't run with three. I'm hittin boost and need to fix the map cause of course I'm gettin the limp home mode when the map reads boost.
Old May 14, 2002 | 08:23 AM
Sonny's Avatar
Default Re: need pics of check valves (Coldsi)
You removed the MAP sensor from the throttle body, correct? Now you are trying to plug the hole in the throttle body? Just cover it with a metal plate and an O-ring.
Sonny
[Modified by Sonny, 5:23 PM 5/14/2002]
Old May 14, 2002 | 08:26 AM
DragII's Avatar
25 Year Member
i just siliconed mine on there, worked like a charm
Old May 14, 2002 | 10:40 AM
xci_ed6's Avatar
Default Re: need pics of check valves (SuperDragII!!!)
So is this a D-series engine? You are supposed to use a piece of hose between the T and the MAP sensor.
-Dustin
Old May 14, 2002 | 03:52 PM
Coldsi's Avatar
Default Re: need pics of check valves (Autocratic_1st_Gen)
I've got the b16A. The car idles really rough with one valve and won't run with three. I guess I'll try the silicone until my missing link comes in, thanks for the help.
Old May 14, 2002 | 04:06 PM
BoostinSOHC's Avatar
I got a missing link on my d16. It works like a charm and looks much better than those check valves. Better boost transition also.
Old May 14, 2002 | 04:49 PM
SlowB16's Avatar
Default Re: need pics of check valves (BoostinSOHC)
I use the check valves and I have no probs with themso far
shaggyeg6si
May 15, 2008 07:48 AM
slither
Sep 20, 2005 10:33 AM
JustAnotherHonda
Aug 6, 2003 04:00 AM
mracura
May 27, 2002 05:54 AM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
