Turbo timer problem
Old May 14, 2002 | 12:20 PM
JMinSi2000's Avatar
Default Turbo timer problem
My Greddy turbo timer wont keep my car on. I've checked my wiring and everythign gets power. My a/c fan stays on though for a minute though then turns off.
Old May 14, 2002 | 01:13 PM
boostedsi99's Avatar
Default Re: Turbo timer problem (JMinSi2000)
did you wire it sowhen you lower the e-brake, the car shut off??also does your radio stays on???
Old May 14, 2002 | 04:51 PM
inspyral's Avatar
Default Re: Turbo timer problem (boostedsi99)
In my car, you have to turn the key quickly from the ON(II) position to the OFF position. If I turn it slowly to the I(1) position before going all the way to the OFF position, my car shuts off and the accessories stay on with the timer. If I do it semi-slowly, my engine shudders for a second and stays on.
Old May 14, 2002 | 07:03 PM
adam's Avatar
make sure you tapped its power into a CONSTANT battery source. also, make sure you got the right ignition wire.
if the timer turns off, chances are you didn't find a constant battery source. hondas have spare connectors that you can use in the under dash fusebox.
Old May 14, 2002 | 07:32 PM
JMinSi2000's Avatar
Default Re: Turbo timer problem (adam)
I tapped into the wires that come out of the thing on the opposite side of the key hole. My accessories and everything stay on too. I'll try that fast turning off thing.
Old May 14, 2002 | 07:48 PM
b18bvudoo's Avatar
New User
hmm...if yor ac fans and accessory are still on then you might have tapped ign2 and acc. you need to tap ign1 to keep the car running.
Old May 14, 2002 | 07:59 PM
JMinSi2000's Avatar
Default Re: Turbo timer problem (vudoo666)
I didnt know there was more than one Ignition on my car.
Old May 15, 2002 | 10:24 AM
adam's Avatar
you'll notice the plastic where those wires are soldered on are labeled. you never said if the turbo timer turns off. does it?
Old May 15, 2002 | 12:24 PM
JMinSi2000's Avatar
I got it fixed...I had it wired to Ign2 instead of Ign1. It all works fine now. How do you turn the sound off on the thing is my next question.
Old May 15, 2002 | 01:46 PM
brcivic411's Avatar
push the select button as it's counting down.
Old May 15, 2002 | 03:36 PM
inspyral's Avatar
Default Re: Turbo timer problem (brcivic411)
online manual:
http://www.greddy.com/technical/turb...ermanualB.html
NightStalker
Sep 3, 2007 01:10 PM
DACteg
Apr 30, 2007 09:32 AM
jBj
Aug 19, 2006 06:53 PM
