injector question
Old May 16, 2002 | 05:35 PM
E Swift's Avatar
Default injector question
i'm looking at getting rc injectors for a b18b need to know if they are peak hold type or saturated ???
thanks in advance
Old May 16, 2002 | 05:48 PM
Nieman's Avatar
New User
Default Re: injector question (E Swift)
RC makes both kinds.
Old May 16, 2002 | 09:40 PM
E Swift's Avatar
Default Re: injector question (Nieman)
But are the saturated one's okay for the B18B motor?
Old May 16, 2002 | 09:55 PM
5 Liter Eater's Avatar
yes.
Old May 16, 2002 | 11:16 PM
B20C5 Turbo's Avatar
New User
Saturated (high impedance) injectors are factory equipment on most OBD-I+ Honda engines. Peak and hold (low impedance) injectors are factory equipment on all OBD-0 (pre-OBD) Honda engines. Either way, all Honda ECU's require @12~14 ohms of resistance between the injector power source and the ECU terminals to prevent driver damage. This means that you have 2 choices:
Saturated injectors may be used with any Honda ECU as long as there *is NO resistor pack* between the power source and ECU terminal(s).
Peak and hold injectors may be used with any Honda ECU as long as there *IS a resistor pack* between the power source and ECU terminal(s).
Old Jun 26, 2002 | 09:56 PM
servion's Avatar
Default Re: injector question (B20C5 Turbo)
What happens if you throw saturated injectors in with a car with a resistor box isntalled? I am thinknig one of my injectors are fired (peak and hold), and I have a setspare of saturated ones I want to test out, but I dont want to mess anything else up...
Can you fry an injector my wirring it wrong? When I wired up my injector resistor box, I had the wires reversed on one of the injector plugs. Since then i have this misifing problem thats been getting worse day by day... it only happens when the car is under load (50% + throttle). I found the wiring problem and swapped them back, but still does the same thing
Old Jun 27, 2002 | 09:48 AM
servion's Avatar
Default Re: injector question (servion)
siguy2k
Aug 19, 2012 09:20 AM
1SicLS
Engine Management and Tuning
Dec 15, 2008 04:16 PM
swt_666
May 16, 2007 09:33 PM
aaronhume
Oct 25, 2005 11:52 PM
