quick question about deltagate wastegate
ok, im settin up my turno right now. I purchases a used deltagate. When i got it... theres two empty holes on top. I know one is for a vacuum line.... but waht do i do with the whole in the middle? any help would be greatly appreciated!
Re: quick question about deltagate wastegate (bumsta217)
if I remember correctly, there should be an allen bolt in the center hole...
this is the adjustment bolt...
there should only be two vaccuum ports available, one on the side of the unit, and one on top, but not in the center, kinda offset...
hope this helps... and keep in mind that I havent had a deltagate for a few years, so I could be wrong...
Re: quick question about deltagate wastegate (trboCIVICWRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trboCIVICWRX »</TD></TR><TR><TD CLASS="quote">if I remember correctly, there should be an allen bolt in the center hole...
hope this helps... and keep in mind that I havent had a deltagate for a few years, so I could be wrong...</TD></TR></TABLE>
ON the money
ON the money
Re: quick question about deltagate wastegate (camp1320.com)
I have the deltagate and I took the bolt out of the top so it would clear my hood and im not using the vacuum line on the top. If you are using a MBC you don’t need the top line.
Just a little info to help
Re: quick question about deltagate wastegate (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout »</TD></TR><TR><TD CLASS="quote">I have the deltagate and I took the bolt out of the top so it would clear my hood and im not using the vacuum line on the top. If you are using a MBC you donÂ’t need the top line.
You took the bolt out? Doesn't that affect its settings at all?
