Wrong GM 3Bar?
Old Sep 25, 2003 | 10:30 AM
Rakka's Avatar
Default Wrong GM 3Bar?
I installed a GM 3bar, and I was rich off the charts at idle, and when you breathe on the gas, it goes off the charts lean. I got the sensor from a friend, so I dont know which part # it is, but the following #'s are on the sensor itself, can anyone plz verify for me?
On the top cover: 466
Bottom Cover: 9576-C6 and >PBT-6F30<
Thx
Old Sep 25, 2003 | 10:38 AM
ladysman's Avatar
Default Re: Wrong GM 3Bar? (Rakka)
I hope you have a standalone and not the stock ecu.
Old Sep 25, 2003 | 11:05 AM
Rakka's Avatar
Default Re: Wrong GM 3Bar? (ladysman)
i am using a nearly stock ecu
Old Sep 25, 2003 | 11:12 AM
legendboy's Avatar
actualy thoes numbers don't mean anything, there like gm's stocking numbers. if you do a search on google you will find that out. the only real way to test it is by measuring the voltage as pressure is applied. or test it with a standalone.
hondamyheart
Jan 26, 2017 06:23 PM
supercoy101
16
Feb 10, 2010 09:09 AM
ZXRider
May 16, 2007 07:50 PM
Stingray96
Nov 1, 2005 09:20 AM
otakueric
Sep 13, 2005 04:49 PM
