OBDII injectors????
Old Sep 25, 2003 | 03:52 PM
ATS*Mark's Avatar
OG triple OG
Default OBDII injectors????
if im reading topics correctly i have to get an obd1 resistor box to run rc injectors right??? any aftermarket injectors that i can just plug and play?
Old Sep 25, 2003 | 03:56 PM
Ben Huynh's Avatar
Default Re: OBDII injectors???? (TURSpoonEK)
You only need to run a resistor box if you want to use peak and hold injectors.
Old Sep 25, 2003 | 04:46 PM
ATS*Mark's Avatar
OG triple OG
Default Re: OBDII injectors???? (ben@importparts.com)
whats the benifit of running peak and hold over saturated????
Old Sep 25, 2003 | 04:58 PM
Ben Huynh's Avatar
Let's put it this way. You want to run the same type inectors your car is already running.
Old Sep 25, 2003 | 06:23 PM
vtec.dc2's Avatar
if you have obd2 car.. all you need is clips for saturated injectors. for peak-n-hold you will need a resistor box.. - no other way around it.
Old Sep 26, 2003 | 04:44 AM
ATS*Mark's Avatar
OG triple OG
Default Re: OBDII injectors???? (vtec.dc2)
what kind of stock injectors do ex motors have?
Old Sep 26, 2003 | 05:06 AM
vtec.dc2's Avatar
all 92-2001 civics/integras run 240cc
Old Sep 26, 2003 | 09:39 AM
ATS*Mark's Avatar
OG triple OG
naw i mean peak hold or saturated?
Old Sep 26, 2003 | 09:55 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">naw i mean peak hold or saturated?</TD></TR></TABLE>
92+ = saturated
Old Sep 26, 2003 | 12:16 PM
Ben Huynh's Avatar
Stock Honda Injectors
1988-91 Civic Si/CRX Si Peak and Hold 240cc
1992-95 Civic Si/EX Saturated 240cc
1996-00 Civic Saturated 240cc
1990-91 Integra Peak and Hold 240cc
1992-00 Integra LS/GSR/Type R Saturated 240cc
1992-96 Prelude Non-VTEC Peak and hold 240cc
1992-96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC Saturated 280cc
Old Sep 26, 2003 | 01:07 PM
Sleepin''s Avatar
All you will need is injector clips (the wire clips that actually attach to the injector) from an obd1 car (most companies that sell injectors also sell clips). ie:Summit Racing etc.
Modified by Sleepin' at 8:16 PM 9/26/2003
Old Sep 26, 2003 | 01:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: OBDII injectors???? (Sleepin')
so would a set of 450cc's be good with a turbo y8 setup??? i jut get saturated and buy the clips?
Old Sep 26, 2003 | 03:23 PM
beerbongskickass's Avatar
DSM 450's will work fine, but you will need resistors because they are peak and hold. You will also need something to control the injectors like the afc hack.
GT500FTW
Nov 29, 2012 03:10 PM
nolicense526
Jul 31, 2007 06:17 AM
boost_is_best
Feb 28, 2006 03:45 PM
abmerop18
Jul 3, 2005 10:32 AM
hybridreams
Sep 12, 2003 09:22 PM
