Want to run 1 bar of boost using hack on built engine.
Old Sep 26, 2003 | 09:53 AM
NOSED_CRX_VTEC's Avatar
Default Want to run 1 bar of boost using hack on built engine.
Hi
Here is what I want to do.
I want to run 1 bar (14.5psi) of boost on my built b16 and still keep with my
450 injectors, my apex i vafc and my MSD btm.
The only thing is a can't run Hondata on a euro spec PW0 ecu and I have not
got a very large budget.
So hit me back with some answers.
Old Sep 26, 2003 | 09:59 AM
hoggy's Avatar
Default Re: Want to run 1 bar of boost using hack on built engine. (NOSED_CRX_VTEC)
There is a big thread on uberdata. I think you should check that out.
Old Sep 26, 2003 | 10:05 AM
5thgencivic's Avatar
1 bar is pretty risky with the hack. Not to mention if you can even get that much boost without a cell... It's been done, but I wouldn't trust it.
Old Sep 26, 2003 | 10:47 AM
InTeGrA B18b1's Avatar
Default Re: Want to run 1 bar of boost using hack on built engine. (5thgencivic)
get a three bar map sensor and some tuning and you should be ok.
Old Sep 26, 2003 | 03:41 PM
TurboJesse
Guest
Posts: n/a
Default Re: Want to run 1 bar of boost using hack on built engine. (InTeGrA B18b1)
I dont' know if the "hack" will work with a 3 bar, a 3 bar will alter the voltage.
Old Sep 26, 2003 | 08:07 PM
90civichbsi's Avatar
Default Re: Want to run 1 bar of boost using hack on built engine. (Mpir3)
you can run the hondata stage 4b on the pwo ecu
Old Sep 27, 2003 | 01:16 AM
EFb18b's Avatar
If I remember right the afc can only go as high as 3.5v or 5v(I can't remember which) In order to reach a 1 bar you'd have to go beyond the stock map sensors "reading" ability. Those of which that have gotten to 1 bar without a different map sensor and no CEL are either lying, gotten lucky, saw a millisecond boost spike, or their CEL light went out. In order to reach your goal safely I would save up a little more money and get some 550 injectors and a semi-standalone. Anything past the stock map sensor's ability is just asking for trouble.
Old Sep 27, 2003 | 01:52 AM
rjardy's Avatar
Default Re: Want to run 1 bar of boost using hack on built engine. (Redlineracer)
i read somewhere that the hack will work with a 3 bar if you change the sensor in out selector on the afc, this manipulates the voltage. Let me see if i can find the thread, I doubt it but I will try.
Rob
EDIT: I cant believe I found it, and only after 2 minutes of searching. Check it out https://honda-tech.com/zerothread?id=531705
Modified by rjardy at 3:06 AM 9/27/2003
Old Sep 27, 2003 | 02:58 AM
Default Re: Want to run 1 bar of boost using hack on built engine. (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">you can run the hondata stage 4b on the pwo ecu</TD></TR></TABLE>
I can't use this system cos it don't work on euro spec only on jdm and usdm ecu's cos they use a knock sensor.
I can either get a jdm pwo ecu and a knock sensor and then run hondata stage 4b or swap to a obd1 ecu from a later honda and run S200 but then I got to then change the dizzy for the later honda and fit a 4 wire o2 sensor.
All of that will cost the big ££££££££ cos I'm in the UK.
Any more ideas
Old Sep 27, 2003 | 03:15 AM
rjardy's Avatar
Default Re: Want to run 1 bar of boost using hack on built engine. (rjardy)
did you not see my post?
Rob
Old Sep 27, 2003 | 05:47 AM
EFb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">i read somewhere that the hack will work with a 3 bar if you change the sensor in out selector on the afc, this manipulates the voltage. Let me see if i can find the thread, I doubt it but I will try.
Rob
Modified by rjardy at 3:06 AM 9/27/2003</TD></TR></TABLE>
Wow! Thats pretty cool man Good Job!
sakasaku
Oct 28, 2010 10:51 AM
00sitk
Apr 30, 2004 09:42 AM
roydogg
Jan 20, 2004 12:53 PM
2ltrsnailpwr
Oct 26, 2003 07:11 PM
-iLLuZioN-B18C1
Sep 18, 2003 11:08 AM
