When is a FMIC too big???
Old Sep 27, 2003 | 05:16 PM
jmal1919's Avatar
Default When is a FMIC too big???
Did a search and not much came up to answer my question.
For a daily driver, running 8psi for a long time, can a fmic be too large? This maybe a noob question, but I was thinking that if I had a fmic that was so large, it blocked air flowing directly to the radiator, that may cause a problem on hot days, or those fun stuck in traffic days. So I was thinking about getting a core which still allowed air to flow directly to the radiator. I have a stock front bumper and will keep it that way.
If I'm thinking too much into this, sorry.
Old Sep 27, 2003 | 05:20 PM
Ricey McRicerton's Avatar
Default Re: When is a FMIC too big??? (jmal1919)
No...you're not thinking too much. Once you are blocking flow to your radiator and stuff...problems occur. Most times, it can be fixed by a pusher fan, but I would'nt go any bigger than the opening that you're planning to fill with IC. I bought a bigger IC than I should have, and am not even using the top portion of it (blocked by the bumper)
Old Sep 27, 2003 | 05:35 PM
jmal1919's Avatar
Default Re: When is a FMIC too big??? (Ricey McRicerton)
So I measured and my opening is about 6" tall, but the FMIC in the fmax kit for my ride is 8" tall. It is shorter though at about 24" with endtanks and I measured 35" up to the splash gaurds. Would a the additional space width wise be good enough to get air to the radiator, or should I also get one which is shorter too?
Old Sep 27, 2003 | 05:41 PM
Nah..I wouldnt sweat it...I have the big Greddy Type 24 FMIC (its almost 30 inches across and dont even know how tall, but 3 inches thick) and have had no overheating problems in my Civic.
Old Sep 27, 2003 | 05:42 PM
jmal1919's Avatar
thanks
Old Sep 27, 2003 | 05:43 PM
If you do end up with overheating problems you can always jack the back of your hood up (I know, ugly, but gets the job done)
Old Sep 27, 2003 | 05:46 PM
jmal1919's Avatar
naw
going for the "Honda Factory Turbocharged" Look
Need to be different!
Old Sep 27, 2003 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmal1919 &raquo;</TD></TR><TR><TD CLASS="quote">naw
Need to be different!</TD></TR></TABLE>
Yeah you and me both man! *except the big fmic kinda gets the head turn every now and then*
Old Sep 27, 2003 | 06:23 PM
jmal1919's Avatar
yet another thing to think about
Old Sep 27, 2003 | 06:27 PM
Racergurlie's Avatar
Its never too big within reason...unless it wont fit!
The bigger the better...dont worry about lag increase and such, its so small its laughable...
Old Sep 27, 2003 | 08:28 PM
2lowintegra's Avatar
Default Re: When is a FMIC too big??? (Racergurlie)
what about pressure drop...? wouldn't you lose pressure by running low boost through a really large ic
haydenpothoven
Jul 16, 2007 07:13 PM
GoFastTshirts.com
Jan 23, 2007 09:25 AM
usafa2010
Dec 17, 2005 09:23 AM
stolenhubcabs
Jul 19, 2003 05:15 AM
R-1303
Dec 26, 2002 09:31 AM
