Some dumb questions
Old Sep 26, 2003 | 08:03 AM
LilManSi's Avatar
Default Some dumb questions
Are there any electronics we would need if going turbo? A map sensor? Or do b16a2's have those. Sorry if this sounds dumb, i just get more and more confused. Or a missing link? I have a ton of questions if anyone would want to talk one on one or something. Also a pick of how the oil return line should be would be nice. Sorry if this is annoying, but i have looked around the site. Thanks
Old Sep 26, 2003 | 08:11 AM
underpressure02's Avatar
Default Re: Some dumb questions (LilManSi)
I guess first off are you going to be running a stock ECU or hondata or an EMS? If you are going to be running stock ECU you will need a missing link and FMU is prob a good idea. Your stock map sensor should be good up to 12psi I believe. What other questions do you have? That is what the FI board is here for.
Old Sep 26, 2003 | 08:59 AM
LilManSi's Avatar
Default Re: Some dumb questions (underpressure02)
It just seems like there are so many things. I would want to do hondata, but i have no clue of anyone who can tune it. I live in Kansas, and i know of a few people who have them (siracer from clubsi) but no of no one to help me install or tune it. Gauges seem like a whole lot of wiring and i doubt if i can do that. Injectors seem like they come with some special clips that i know nothing of. It just confusing, but once i learn it will be worth it. Thanks for your help,
Old Sep 26, 2003 | 10:02 AM
Gauges are usually pretty easy to install. There is usually a power, ground, and then aux and one for the input. I am sure there are plenty of people on here that can help you if you have questions.
I do not know what to tell you about the hondata since I am not from around there. You may have to drive a little bit of a distance to get a good tuner.
As far as the injectors go there should be some good write ups on here that can help with the install. Here is a good write up on how to install the resistor pack.
https://honda-tech.com/zerothread?id=517274
Hope that helps.
Old Sep 26, 2003 | 11:22 AM
LilManSi's Avatar
what is a resister pack.(i told you i had some dumb questions)
Old Sep 26, 2003 | 03:00 PM
LilManSi's Avatar
ne one?
Old Sep 27, 2003 | 08:31 AM
LilManSi's Avatar
bump
chrisfromsrq
Sep 26, 2009 12:20 AM
R6E6I6D
Nov 14, 2005 09:18 AM
crush
Jun 5, 2005 12:16 PM
Acura_I-RS
Mar 16, 2003 06:53 PM
SoulSurfer
Jan 7, 2003 08:00 AM
