SMC+ 450cc code 45
Old Sep 25, 2003 | 05:36 AM
strangerqc's Avatar
Default SMC+ 450cc code 45
Hi guys,
I've installed a SMC+ and a set of 450cc dsm injectors, and I'm getting a code 45 (rich or lean) after around 50km. All my settings are at -40%. Is it normal ?
And i noted that i'm going in the rich zone when i should'nt, like when i just touch the gaz pedal (verry low throttle).
My DSM's was'nt cleaned prior to use, is it the kind of symptoms i would get ?
Thanks
Old Sep 25, 2003 | 06:28 AM
keebler65's Avatar
Default Re: SMC+ 450cc code 45 (strangerqc)
are you tuning it with a wideband? (i hope?) if so, what are the readings.
Old Sep 25, 2003 | 06:55 AM
strangerqc's Avatar
Default Re: SMC+ 450cc code 45 (keebler65)
Plugs reading and A/F ratio. I did'nt realy tuned it yet, only the idle is tuned to make it smooth. I should go to the dyno soon and use a lambda.
My plugs are perfect brown, but my A/F ratio show rich for a few seconds (and closed loop behaviour) when i'm at verry low throttle, then go back to open loop in stoich area. When i'm at full boost and WOT the car is pulling hard, and stay in the rich zone.
Old Sep 25, 2003 | 10:57 AM
strangerqc's Avatar
anyone ?
Old Sep 25, 2003 | 11:07 AM
Maxime's Avatar
I get this code once in a while. Usualy when I am accelrating (boosting) at part throttle.
You are probably running too rich. You should tune your car on a dyno with a wideband.I was running way too rich at high rpm. I gained 50whp.
Old Sep 25, 2003 | 12:01 PM
strangerqc's Avatar
Default Re: SMC+ 450cc code 45 (Maxime)
Thank you Maxime
94typeR
Mar 31, 2007 03:57 PM
mp5o
Apr 14, 2005 11:38 AM
boosted k20
Sep 11, 2004 07:32 PM
ActiveAero
Sep 14, 2002 01:03 AM
