msd start retard and zex
Old Sep 25, 2003 | 03:08 PM
dseriessol's Avatar
Default msd start retard and zex
i am using a start retard module to retard my timing when spraying but since its a zex kit and uses a tps instead of a micro switch I don't know where to run the wire to retard the timing
Old Sep 30, 2003 | 12:13 PM
untitled's Avatar
Default Re: msd start retard and zex (dseriessol)
tap into the wire coming from the zex box to the tps. that wire is the microswitch wire. whenever it sees the max volt(4.90-.99) from your tps wire it clicks the solenoid on, which would essentially do the same as a microswitch.
noss88
Apr 19, 2007 09:28 PM
EX-T
Jul 22, 2003 08:50 PM
Tchleung
Jul 20, 2003 10:11 PM
MidoriEK4
May 18, 2003 09:08 AM
aemciv
May 8, 2003 12:54 PM
