gsr turbo vacuum problems... help!!!
Old Sep 26, 2003 | 01:09 AM
BoOsTiN Dc2's Avatar
Default gsr turbo vacuum problems... help!!!
Ok, i seem to have a vacuum problem with my turbo. i never hear the bov go off ever since i installed my turbo. here is what i have on my car
greddy type r bov, hks 40mm wastegate, b&m fpr, some kind of fmu (think its vortech), check valves, stock injectors.
Ok, i got my bov connected to the vacuum on the throttle body.
The 2nd vacuum is off the intake manifold, near the butterfly off the gsr intake manifold.
Vacuum then the 4 fitting splits off to the fpr then boost guage, then another 4 fitting splitter to the fmu and the wastegate.
Sorry if i didnt make myself clear enough.
1st vacuum > bov
2nd vacuum > splitter > fpr, boost guage > splitter > fmu > wastegate
Not sure what size line im running. Can anyone suggest a better way or help me figure out why my bov isnt going off? i tried my friend's greddy type r bov and its still the same thing, air is coming out but i dont hear it. also i'm running open down pipe.
Old Sep 26, 2003 | 02:17 AM
HYBRID_H@TCH's Avatar
Default Re: gsr turbo vacuum problems... help!!! (tRaCeBuStAbUsTeR)
ok let me try this out.
what psi are you running?
and with all the lines you have tee'd/split in to it seems you have a week vac source.I would go with a golden eagle vac manifold or if your broke/cheap drill and tap a few ports in the manifold that will get a better vac source.I had my BOV tee'd to my fpr and it worked but not well..so I drilled/tapped a 1/8 npt port in my mani right near the TB and now its all good..but a vac manifold would be the best option.
38 bucks shipped from camp1320.com
Old Sep 27, 2003 | 03:00 AM
im running at about 8-9 lbs
Old Sep 27, 2003 | 04:20 AM
MI4eg's Avatar
are you taking it to full boost..i know because if the size of my turbo my BOV doesnt sound off unless im at full boost
Old Sep 27, 2003 | 12:47 PM
full boost, low boost, no boost = no sound. also in 3rd gear my engine check light turns on and start bogging and running hella shitty. and i smell a lot of unburn fuel. anyone know what it can be? think im running to lean.
Old Sep 27, 2003 | 02:58 PM
boosted_dc2's Avatar
Default Re: (tRaCeBuStAbUsTeR)
your probably running rich, if you check engine light comes on then its probably going into limp mode. Check you check vaves, i bet if you check the code it will be map sensor. also make sure your vacume line for your bov is AFTER the throttle plate, (ie: intake manifold)
Old Sep 28, 2003 | 03:56 AM
ok now after i got my down pipe the engine check light turns on at end of 3rd gear to 4th gear and goes into limp mode. do anyone think im leaning out boosting close to 9 lbs with stock injector... just with fmu, 255lph fuel pump and fpr.
Old Sep 28, 2003 | 10:14 AM
hulkhb's Avatar
isn't the type r bov for 12 + psi ? that may be why is does sound to loud.
As far as you 12,000 vaccum lines you need to get a Vaccum bar, as mentioned above. That will go from the brake booster to the intake manifold, that is where the largest amount of vaccum is. try that out.
Old Sep 28, 2003 | 10:53 AM
TurboedGSR's Avatar
use the brake booster line
fmu* vac source
Old Sep 28, 2003 | 11:23 AM
egturbo's Avatar
Default Re: gsr turbo vacuum problems... help!!! (TurboedGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboedGSR &raquo;</TD></TR><TR><TD CLASS="quote">use the brake booster line
fmu* vac source</TD></TR></TABLE>
does that affect braking performance? just wondering.oh and can a greddy profec B boost controller and boost guage go on that golden eagle thingy?
Old Sep 28, 2003 | 11:34 AM
Del's Avatar
Del
tighten the **** out of the spring.... the Type R is super quiet at low PSI
Old Sep 28, 2003 | 08:15 PM
TurboedGSR's Avatar
Default Re: gsr turbo vacuum problems... help!!! (egturbo)
not likely to brake under boost so no
Dan_Roc
Feb 6, 2007 12:55 PM
520_Motorsports
Apr 27, 2005 07:42 PM
yisoulja
Mar 16, 2003 09:22 PM
01ITR#700
Nov 16, 2002 12:59 PM
NeXtLeVeL_TyPe_R
May 15, 2002 11:45 AM
