help with greddy turbo
Old Sep 26, 2003 | 11:38 AM
monkijunki's Avatar
Default help with greddy turbo
ok, im newbie at this, so bear with me. i have a gsr greddy turbo kit with intercooler. on the turbo, there's the rigth side which looks all red and rusty, then there's teh shiny side that looks like metallish. on the metallish side, there's a yellow thingy on it that supposedly im suppose to connect a vacumn line to it, but the thing the vacumn line's suppose to connect to (the male end of the yellow thing) is broken off. is there a quick fix, or somewhere i can go to replace it?? i'll post pics later tonite when i get off school. it's hard to explain it =/
Help me, im lost sleep thinking bout it last nite,
-Huy
--------------edit--------------
here are some pics. if the links dont work, just copy and paste it into a new browser. it should work like that.
http://www.geocities.com/monkijunki/greddy_turbo1.JPG
http://www.geocities.com/monkijunki/greddy_turbo2.JPG
what options do i have with that??
Modified by monkijunki at 10:55 PM 9/26/2003
Modified by monkijunki at 11:03 PM 9/26/2003
Old Sep 26, 2003 | 01:58 PM
Pengo's Avatar
Default Re: help with greddy turbo (monkijunki)
ok, so the nipple on ur wastegate has broken off. i dunno if u can get it welded back on or not, it is quite a small item but it could possibly be done by a skilled welder. just make sure that hole doesnt get blocked or plugged up. as a last resort u could replace the internal wg or get one off a junker
monkijunki's Avatar
help...anyone??
Old Sep 26, 2003 | 02:01 PM
monkijunki's Avatar
Default Re: help with greddy turbo (Pengo)
oh, so that's the "internal wastegate"?? i would rather replace it cuz the hole is pretty damn small to align up. anyone got an extra greddy external waste gate for sale? or anyone know where i can get one?? im a newbie =/
Old Sep 26, 2003 | 05:54 PM
monkijunki's Avatar
anyone got a broken greddy 18g turbo?? i'll buy the yellow wastegate off of you.
Old Sep 26, 2003 | 06:18 PM
Maxime's Avatar
This?
Mine was broken. I replaced it with a Dodge 2.2L Turbo unit.
Old Sep 26, 2003 | 09:17 PM
monkijunki's Avatar
Default Re: help with greddy turbo (Maxime)
yeah, that's the one. anyone have that shiny yellow thing whose willing to sell it??
let me know, thx.
Old Sep 26, 2003 | 09:25 PM
B94Cast's Avatar
If you cant find the part, you could always get a Tap set. Drill then tap the hole. Put in a NPT fitting of the appropriate size. Seal the threads with some good high heat silicone.
Rather "ghetto" approach, but if it works, then go 4 it.
Old Sep 26, 2003 | 09:34 PM
GLHS895's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxime &raquo;</TD></TR><TR><TD CLASS="quote">
Mine was broken. I replaced it with a Dodge 2.2L Turbo unit. </TD></TR></TABLE>
there are shitloads at junkyards. that can be good or bad...
Old Sep 26, 2003 | 09:36 PM
monkijunki's Avatar
Default Re: help with greddy turbo (B94Cast)
get a Tap Set eh? what's a tap set and where do i get one?? i called up greddy earlier, they said it would cost close to $150 to replace it. $150 !!! i gave him the finger (which he didnt see), said 'good day' then politely hanged up the fone &gt;
Old Sep 26, 2003 | 09:40 PM
monkijunki's Avatar
by the way, what does the yellow thing do anyway? it seems to be hollow, and one end is connect via a metal pole to the turbo. if i get a new one, can i just bolt it somewhere else instead of on the turbo?
Old Sep 26, 2003 | 09:56 PM
chri5's Avatar
You dont need it, just run without it hooked up. It'll help you get more boost!
Old Sep 26, 2003 | 10:39 PM
GLHS895's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monkijunki &raquo;</TD></TR><TR><TD CLASS="quote">by the way, what does the yellow thing do anyway? it seems to be hollow, and one end is connect via a metal pole to the turbo. if i get a new one, can i just bolt it somewhere else instead of on the turbo?</TD></TR></TABLE>
it's a vacuum diaphram. vac/boost pressure moves the little diaphram inside which moves the rod and opens/closes the wastegate 'trap door' to regulate boost.
hope that helps
Old Sep 26, 2003 | 10:51 PM
monkijunki's Avatar
Default Re: help with greddy turbo (GLHS895)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">it's a vacuum diaphram. vac/boost pressure moves the little diaphram inside which moves the rod and opens/closes the wastegate 'trap door' to regulate boost. </TD></TR></TABLE>
i c. what would happen if i ran without it?? or does anyone know how to convert the greddy inernal wastegate into using an external waste gate?
Old Sep 27, 2003 | 04:50 AM
GreddySi99's Avatar
you seriously need to do lots of reasearch before you even drive your car your **** will blow up in 2 weeks if you dont have an idea about what the turbo system involves. study my boy study
Old Sep 27, 2003 | 07:38 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: help with greddy turbo (intercooledJRSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">you seriously need to do lots of reasearch before you even drive your car your **** will blow up in 2 weeks if you dont have an idea about what the turbo system involves. study my boy study </TD></TR></TABLE>
Word. You seem like WAAYYY too much of a turbo n00b to be boosting your ****. I researched for a YEAR before I boosted mine a month ago, and since I installed it myself, I feel that if anything is wrong with the turbo setup I should be able to at least diagnose it myself, if not fix it.
RESEARCH!
Old Sep 27, 2003 | 09:23 AM
monkijunki's Avatar
Default Re: help with greddy turbo (boostincoupe)
im a noob, that's y i went with greddy. my stepsister's uncle knows a lot bout turbo and stuff, so im not worried. he's gonna install it for me but i just want to make sure i have everything ready for him. for now, imma try welding in a small tube, if that dont work, i guess i gotta replace the whole thing =/
Old Sep 27, 2003 | 10:08 AM
GLHS895's Avatar
i c. what would happen if i ran without it?? </TD></TR></TABLE>
lol. too much boost. then, "KABOOM" goes your motor.
Old Sep 27, 2003 | 10:16 AM
Frozen E's Avatar
H-T White Ops
b16excoupe
May 19, 2013 05:57 AM
iamthefollower
Nov 15, 2009 09:21 PM
97CWITR
Nov 9, 2005 07:39 PM
DC2uNer
Mar 4, 2004 03:59 PM
