JE Piston ring end gap?
Old Sep 25, 2003 | 10:49 AM
Aeka GSR's Avatar
New User
Default JE Piston ring end gap?
What do you guys reccomend for the end gaps of a b18c1 standard bore with JE pistons with a turbo?
Old Sep 25, 2003 | 10:57 AM
paulzy's Avatar
Default Re: JE Piston ring end gap? (Aeka GSR)
look on teh yellow piece of paper that came with the pistons. It has the calculations to find your gap. Just calculate it out
Old Sep 25, 2003 | 11:05 AM
PrecisionH23a's Avatar
How much boost are you looking at running?
Old Sep 25, 2003 | 11:08 AM
Killer_B's Avatar
call JE and ask them. tell'em it for FI.
Old Sep 25, 2003 | 12:18 PM
boostaholic's Avatar
Default Re: (Killer_B)
The end gaps are going to be different for the top and bottom rings. Your pistons should have come with a spec sheet or call JE for the end gap settings. For moderate street boost, it'll probably be around .005" per inch of bore.
Old Sep 25, 2003 | 01:56 PM
Zero2Sixty's Avatar
Default Re: (boostaholic)
my top ring is at .016 and second ring is .017 and thats for forced induction.
Old Sep 25, 2003 | 03:05 PM
servion's Avatar
Default Re: (Zero2Sixty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zero2Sixty &raquo;</TD></TR><TR><TD CLASS="quote">my top ring is at .016 and second ring is .017 and thats for forced induction.</TD></TR></TABLE>
What kind of oil consumption issues do you have with these gaps? I set both of mine at 18 thousandths, and I consume a fair amount of oil
Old Sep 25, 2003 | 04:17 PM
Aeka GSR's Avatar
New User
I'll be boosting around 15 lbs. Yeah I got the paper, I just wanted to cross check with you guys to see if there was a "better" fit. Also, where the hell do you get a ring file tool? Or is it ok to go at em with a regular file? This is my first set of rings that actually say its ok to file.
Old Sep 25, 2003 | 04:44 PM
torr's Avatar
i'd say get the standard fit rings, to fit your pistons. that way you don't have to file.
Old Sep 25, 2003 | 06:15 PM
Aeka GSR's Avatar
New User
Default Re: JE Piston ring end gap? (torr)
I already got my rings, they were reccomended to me. The rings are made by the same company that makes the JE pistons but JE doesnt want to switch to this particualr set of rings. Who knows, maybe they dont need to be filed, i'm to lazy to check the gap right now, hehe.
Old Sep 28, 2003 | 04:14 PM
Zero2Sixty's Avatar
Default Re: (servion)
i have none so far, on all motor
Old Sep 28, 2003 | 05:40 PM
2old_honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aeka GSR &raquo;</TD></TR><TR><TD CLASS="quote">Also, where the hell do you get a ring file tool? Or is it ok to go at em with a regular file? This is my first set of rings that actually say its ok to file. </TD></TR></TABLE>
get this tool from summit http://store.summitracing.com/...image
Its only $32 and works great!
turbodcxbro
12
Jul 4, 2011 08:43 PM
Trailz-EX
Dec 1, 2004 07:50 PM
Boostless97Lude
Jun 4, 2003 08:07 AM
boostaholic
Mar 25, 2003 09:43 PM
Thats-so-Ls
Dec 29, 2001 07:17 AM
