Afc-hack setting using V-afc without vtec
Old Sep 27, 2003 | 11:55 AM
89dxhunchback's Avatar
Default Afc-hack setting using V-afc without vtec
I had a vtec motor, b=now I don't. I added a turbo, now I need to know what settings should be on all the stuff that concerns vtec. Cross-over points, and which map if not both should I tune ?
IE:
High cam ,Low cam, full throttle, narrow throttle...
Right now I just set the cross over point to 7000roms ( the highest it will go ) and tuned the "low cam, WOT" and " low cam, narrow Throttle"...
Set-up is a d16, TD04L-13T, 450cc DSMs...
Any help would be great.
I'm not confused about how the AFC hack works, just need help getting around the "V" in the "V-AFC"..
Old Sep 27, 2003 | 01:54 PM
LbcJiGGa's Avatar
Default Re: Afc-hack setting using V-afc without vtec (89dxhunchback)
homemadeturbo.com has a section on the v-afc hack. check them out. I got my settings from that website and my car runs excellent at 9 psi with hack without tunning.
Old Sep 27, 2003 | 02:47 PM
xci_ed6's Avatar
Default Re: Afc-hack setting using V-afc without vtec (LbcJiGGa)
Set the VTEC x-over wherever you normally would and tune from there. The wire is hooked up to nothing so ith works fine. Mine went something like:
VTEC
RPM__%
1000_-40
2000_-40
3000_-40
4000_-40
4500_-40
5000_VTEC X
5500_-40
High VTEC
4500_-40
5000_VTEC X
5500_-40
6000_-40
7000_-40
8000_-40
Wow, that is not very close, I havn't even checked my settings in a couple months. That should explain it though.
I wrote about how to tune with the TPS input hack awhile ago. If you want to know how to do that let me know.
-Dustin
2lobes1engine
15
Apr 12, 2004 10:33 AM
GOLDBERG
Feb 16, 2004 10:51 AM
98R-1144
Nov 4, 2002 05:12 PM
Wet Nudl
Feb 25, 2002 01:46 PM
EGtoR
Jan 19, 2002 11:27 PM
