12:1 fmu vs dsm injectors and aem fpr
I am planing to run 5 psi for a little while until my turbo breaks in. what is better? running a votech 12:1 fmu or going with dsm injectors and an aem fpr to turn it down. Which way is better and which way is cheaper. What else do you have to run with the fmu if i went that way?
Re: 12:1 fmu vs dsm injectors and aem fpr (integra95)
i am trying to ran a vortech fmu. i also have a aem frp. i was told by aem not to use there fpr as an only source for boost dependent fuel source. a friend of mine wanted me to run my car with just the aem fpr and rc 370's with 255 pump. i am not sure if you should run your car with just aem fpr. maybe your car is different than mine!
fmu route you will need the fmu and fuel pump
dms injector route you will need the injectors, resistor pack, and a fuel computer to control those injectors (s-afc, v-afc)...just turning the fuel pressure down won't do anything for you
