Another Wideband 02 Question
Old Sep 27, 2003 | 04:06 PM
Ricey McRicerton's Avatar
Default Another Wideband 02 Question
Hey guys, my stock 02 is crapping out and Im looking to upgrade to a wideband o2 sensor. Is there any way that I can get an aftermarket wideband 02 sensor and use it for tuning, but also use it to send the signal to my car as the primary o2 sensor. Thanks a bunch guys!!!
Old Sep 27, 2003 | 04:19 PM
Default Re: Another Wideband 02 Question (Ricey McRicerton)
I need this wideband to "talk" to my Greddy E-Manage and the stock ECU if I was a little unclear in my original post. Thanks!
5thgencivic's Avatar
The FJO will. I think the AEM does too, but doesn't have a display.
Old Sep 27, 2003 | 04:23 PM
Default Re: Another Wideband 02 Question (5thgencivic)
Thanks...I need the display...so the FJO has the stock connector and then has more wires to run the display?? Sorry about all the Noob ?s..I searched, but most of the WB02 stuff I found was just sensors for sale. Thanks!!!
Old Sep 27, 2003 | 04:24 PM
civperc's Avatar
the wideband from innovatemotorsports.com can replace and act as the stock o2 sensor right?
Old Sep 27, 2003 | 04:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Thanks...I need the display...so the FJO has the stock connector and then has more wires to run the display?? Sorry about all the Noob ?s..I searched, but most of the WB02 stuff I found was just sensors for sale. Thanks!!!</TD></TR></TABLE>
You will have to splice a connector on the FJO wires http://www.hondata.com/techwidebandtuning.html PM me if you have any more questions. Would be glad to help. I got confused before and even had the FJO in hand
Old Sep 27, 2003 | 04:35 PM
Default Re: Another Wideband 02 Question (untensadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untensadude &raquo;</TD></TR><TR><TD CLASS="quote">the wideband from innovatemotorsports.com can replace and act as the stock o2 sensor right?</TD></TR></TABLE>
The LM1 doesn't have a narrowband output I don't think so you will have to keep the stock o2 and weld another bung.
Old Sep 27, 2003 | 05:08 PM
Cool!! Thanks a bunch man!! Do any other widebands work..the FJO is a little pricey for me (college kid)
Old Sep 27, 2003 | 05:12 PM
No problem man. http://www.techedge.com.au/veh...t.htm
Old Sep 27, 2003 | 05:15 PM
such as the Tech Edge 1.5 Wideband??
hahah dang..you beat me to it!! You're the man!!! How much would you pay for a used one?? Edit number 2: Is 325 shipped too much for a used one??
EDIT: Also, I will need to splice the OEM plug onto the end to get it to work with the stock ecu correct?
Modified by Ricey McRicerton at 2:31 AM 9/28/2003
Old Sep 27, 2003 | 05:36 PM
R6Elmo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">
The LM1 doesn't have a narrowband output I don't think so you will have to keep the stock o2 and weld another bung.</TD></TR></TABLE>
Hey man, try not to give wrong information. The http://www.innovatemotorsports.com wideband LM-1 DOES mimick the regular narrowband output to yhour stock ecu. THe reason i know is because i have the wideband and i also am familiar with it's programming. It has two analog outputs that you can program. STock 02 sensor voltage is about 0.1V (lean) - 0.9V (rich). The LM1 can do it. It's also more than 1/2 the price of the FJO.
But If i were you, i'd just purchase another stock 02 sensor and run that. Using the wideband in there as the stock 02 sensor runs too many variables IMHO. If you want to take it out to tune someone elses car, or if you want to sell it. You can purchase a bosche replacement sensor for about 50-70 bucks. You can get a used sensor on teh board fgor 15-30 bucks.
Danny
Old Sep 27, 2003 | 05:38 PM
Default Re: Another Wideband 02 Question (R6Elmo)
Not to be an ***, but he said that he didnt "think" it would work. He didnt say for sure...he's just trying to help all us unknowing WB02 starters here!!
Old Sep 27, 2003 | 07:08 PM
I musta missed it when I looked at the site hence why I put "I don't think". Does look like a nice unit though.
Old Sep 27, 2003 | 07:27 PM
scttydb411's Avatar
techedge 2.0 and 7 series sensor. if you already have a palm pilot you can view, log, and send narrow band signal. just barely 300 shipped for 2.0 and sensor.
Old Sep 27, 2003 | 08:21 PM
Default Re: (scttydb411)
Where did you find that price and does that include a display??
Old Sep 27, 2003 | 09:55 PM
1fstevo's Avatar
New User
but if your stock O2 is crapping and you are still using the stock ecu unless it's hondatad, you will still need a new O2 regardless if you are getting wideband or not.
Old Sep 28, 2003 | 10:05 AM
scttydb411's Avatar
haven't tested it out yet, but the techedge 2.0 has the ability to send a narrowband signal to the ecu.
the 2.0 unit is 279 shipped to the states from techedge directly from http://www.wbo2.com, the sensor is 36 shipped from http://www.1stvwparts.com, and i use a palm IIIc for display, logging, playback. great way to go and then you are no longer the dyno tuners bitch.
balbowskie
Engine Management and Tuning
Apr 8, 2013 10:00 AM
themorphious
Jun 29, 2006 06:36 PM
birz
Jan 14, 2004 04:39 PM
RTW DC2R
Jul 16, 2003 05:42 AM
