how can you tell if you have a blown head gasket???
Old 09-24-2003, 07:57 PM
DOHCarp's Avatar
Default how can you tell if you have a blown head gasket???
my b18c1 keeps overheating for no reason when Im driving. when Im at idle it seems to be fine, but when I am on the highway or driving it starts to over heat, and fills my overflow tank. I tried changing my thermastat, and bleeding the radiator, but it still overheating, and filling the overflow tank.
I also just changed my oil and there was no sign of anything in the oil, but in some of the coolent I can see some black specs in it, can that be oil?
please help me find what the hell is wrong, my car feels faster then ever and I need to have it ready to race on sunday at maple grove.
thanks
Old 09-24-2003, 08:10 PM
Foozball26's Avatar
Default Re: how can you tell if you have a blown head gasket??? (DOHCarp)
get a leakdown test, that will show you if you there is any leaking part.
also the head could be lifting under boost, but if it happens just while cruising then that shoulnt be the case
Old 09-24-2003, 08:13 PM
vtec.dc2's Avatar
are you loosing coolant? try doing coolant pressure check - that may reveal where or if you have a leak
Old 09-24-2003, 08:17 PM
DOHCarp's Avatar
Default Re: how can you tell if you have a blown head gasket??? (vtec.dc2)
I dont seem to be losing coolent, it just goes into the overflow tank.
Old 09-24-2003, 08:19 PM
shadow103rd's Avatar
If you have Oil in you radiator or in your reservoir then you have a blown head gasket.....when mine blown I would lose coolant and oil showed up in my radiator
Old 09-24-2003, 08:47 PM
DOHCarp's Avatar
Default Re: how can you tell if you have a blown head gasket??? (shadow103rd)
I cant tell if it is oil in my radiator, I do see small black/brown specs in the fluid.
I just did a hard run 5 minutes ago. my car will idle all day withought over heating, but as soon as I get on the gas it will start to overheat.
also I do have a lot of condensation in my exhaust. I left a trail of water down my street.
Old 09-24-2003, 09:20 PM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">I cant tell if it is oil in my radiator, I do see small black/brown specs in the fluid.
do these specs look like an oil spill in the ocean kinda?
you can always take teh rad. cap off, let car idle and see if it bubbles. If it does, you have a leak in teh HG
silent702
02-09-2010 08:22 AM
cristegra09
05-14-2009 11:45 AM
ujhonda
05-11-2006 04:29 PM
EK k kay
16
01-01-2005 12:27 AM
Quick Reply: how can you tell if you have a blown head gasket???
