Wideband O2 question, tuning with uberdata most likely
Old 09-25-2003, 04:40 PM
94lsboost's Avatar
Default Wideband O2 question, tuning with uberdata most likely
As the title says i'll most likely tune with uberdata. The setup will be garret turbo tb0343 i believe, 10 lbs = full boost , stock b18b 94 ls. I know I need a wideband o2 sensor to tune with, my questions are as follows? Which is best, for the least money? Should i leave it hooked up for good to get real-time readings forever? If so, is there a gauge I can hook it to? or do i just need the digital screen or whatever it reads thru as you tune?? any info greatly appreciated, this is the only shady area for me in this install...
Old 09-25-2003, 05:22 PM
xenocron's Avatar
Default Re: Wideband O2 question, tuning with uberdata most likely (94lsboost)
https://honda-tech.com/zerothread?id=599740
Vryantec
Engine Management and Tuning
18
07-31-2018 03:35 AM
onlinehost
09-06-2011 07:04 AM
Tyler_Durden
06-13-2003 06:36 PM
3gLudeH22A
12-13-2002 02:45 PM
gcajnr21
01-29-2002 10:46 PM
Quick Reply: Wideband O2 question, tuning with uberdata most likely
