How do you install a MBC on a greddy turbo?
i'm thinking of getting the joe p mbc, but i want to know how to install it.
i have the greddy turbo with the blitz bov.
on there turbo, there's a vacum line going from what i think is called the westgate. would i use that line to connect to the mbc?
would i Tee off the line from the BOV and connect that line to the mbc as well?
pics would help if anybody has one installed.
thanks
thanks
Re: How do you install a MBC on a greddy turbo? (93hb)
no. on the wastegate there should be a vaccum hose going from it to the compressor housing. Take that off. Run a vaccum hose from the MBC to the wastegate, and from the MBC to the intake manifold. Make sure you block off the hole in the compressor housing.
Re: How do you install a MBC on a greddy turbo? (eh6turbo)
okay...i saw the vacum line on the turbo coming from the westgate. so i use that line and put it to the mbc, right? then i cover up the hole on the housing where that vacum line went to from the westgate right?
the other line goes to the intake manifold somewhere, right? so can't i just tee off the bov since thats going to the intake mani as well?
Courtesy of turboxs.com ...
You can read the explanation here... http://turboxs.com/standard_boost_controller.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb »</TD></TR><TR><TD CLASS="quote">okay...so is that the way it goes in the pic or does one end go to the intake manifold?</TD></TR></TABLE>
if you use that source, your motor will be producing a little bit less boost, because the vacuum source isn't after the intercooler (pressure drop) the bov (possible leak), etc...
I would plug up the hole in the compressor housing and instead of having the tube from from there, i'd have it from from the intake manifold.
-ryan
-ryan
