Quick yes/no question...
Old Sep 27, 2003 | 07:53 AM
Infinity_Racer's Avatar
Default Quick yes/no question...
Air is blowing through my oil cap when i open it while idling...Would this mean that my rings are shot/f*cked? Doing a compression test in a little bit when my dad gets home, so i guess that will let me know, but i'm just wanting to know ahead of time...
Old Sep 27, 2003 | 08:49 AM
B20T's Avatar
Default Re: Quick yes/no question... (Infinity_Racer)
No
Old Sep 27, 2003 | 08:51 AM
Ri5e's Avatar
Default Re: Quick yes/no question... (B20T)
Is there a lot of air? Do this, while it's idling, take out your oil dip stick and if exhaust smokes come out, then your rings or ringlands are dead
Old Sep 27, 2003 | 08:56 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">Air is blowing through my oil cap when i open it while idling...Would this mean that my rings are shot/f*cked? Doing a compression test in a little bit when my dad gets home, so i guess that will let me know, but i'm just wanting to know ahead of time...</TD></TR></TABLE>
there should be smoke.. out the oil cap or breather valve.. but do a compression test even if theres no smoke.. better to see signs that way before it blows up..
Old Nov 5, 2003 | 06:26 PM
Default Re: Quick yes/no question... (vtec.dc2)
ok well i did the compression test and here's what i got...
from passenger side to driver side
165, 160, 180, 160
When i went to take the spark plugs out i noticed the far right one on the drivers side was loose...so i thought that was the cause of the air coming out of the oil cap, but after i did everything, there's still air coming out of it...
anyone have any ideas?
Old Nov 5, 2003 | 08:05 PM
bump before bed
Old Nov 5, 2003 | 08:12 PM
keebler65's Avatar
the loose plug wouldnt cause the air. was the motor cold/warm/or hot when you did the compression test? those numbers seem low...what motor is this?
Old Nov 5, 2003 | 08:25 PM
Default Re: Quick yes/no question... (keebler65)
the motor was warm...its on a d16z6...people from the EG forum said it was normal for the air blowing out of the oil cap? /
Old Nov 5, 2003 | 08:33 PM
lazerus's Avatar
combustion chamber leakage is normal (crankcase pressure) you can always do a compression and leakdown test to see how much leakage there is, and determine if there is in fact a problem.
Old Nov 5, 2003 | 08:36 PM
Default Re: Quick yes/no question... (lazerus)
is there a how-to on how to do a leak down test? never done that before...
just checked my PCV valve and its still fine...i can still hear it making the clicking sound when i shake it...i just cleaned it up a bit and theres only a little bit of air coming from the cap...that normal?
Modified by Infinity_Racer at 10:43 AM 11/6/2003
Old Nov 6, 2003 | 06:42 AM
bump before school
Old Nov 6, 2003 | 06:55 AM
30psi Teg's Avatar
There is always going to be a little crankcase pressure even at idle. Now if it is smokin bad out the crankcase breather then you probably have a problem. run the compression test once more, your numbers do seem a little low make sure you crank the engine over several times then I usually stop and crank a few more after that
Old Nov 6, 2003 | 10:23 AM
Default Re: Quick yes/no question... (30psi Teg)
whats a good compression for a d16z6 with 0ver 180k miles?
Old Nov 6, 2003 | 07:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">whats a good compression for a d16z6 with 0ver 180k miles? </TD></TR></TABLE>
boostedh22lude1
Oct 24, 2007 02:01 AM
Fat Chick Magnet
Nov 24, 2006 02:50 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
nekoabandoned
Jul 24, 2006 03:39 PM
aut0tek
Apr 10, 2004 08:30 PM
