Oil return line?
Old Sep 27, 2003 | 05:38 PM
LilManSi's Avatar
Default Oil return line?
Hey peter, whats happenin? If i could get a picture of, or a description of a proper oil return line and the wrong one(position) that would be greeeaaat. Thaannks.
Old Sep 27, 2003 | 05:39 PM
Ricey McRicerton's Avatar
Default Re: Oil return line? (LilManSi)
I put mine on the far side of the oil pan (under the timing belt side pointing forward and angled up) but have seen them on the front of the pan also. Get it welded on..you won't regret it.
Old Sep 27, 2003 | 05:47 PM
reignofchaos's Avatar
Default Re: Oil return line? (Ricey McRicerton)
the top part is what you have in your sinks at home draining... as long as point A is higher than point B, you are fine, it will still drain, that's how your sink works
you ask why? see that red dotted line, once water fills up to that red line in the "U" shaped part, from physics and gravity, more water poured into the inlet will push it passed the "U" shaped and drain. the water will never go higher than the red dotted line in the inlet
same things goes for the oil line, people freak out and scream their dog's name out when they see the fitting on the oil pan is not tottally down, it doesn't need it be, you can have it go zig zagging, as long as point on your turbo OUT is H I G H E R than the point on the oil pan... it will drain.
the pic of the oil return i drew is how my oil return is, you don't see my complaining about turbo's smoking or "i blew my seals"
boosted for over 1 month.
AND MY OIL LEVEL IS THE SAME, i didn't burn anything.
Old Sep 27, 2003 | 05:51 PM
Default Re: Oil return line? (reignofchaos)
Haha..great pictures man!!! Boosted for over a MONTH!!! Man...you're like the all knowing turbo king (just messing with you man!)
Old Sep 27, 2003 | 07:59 PM
LilManSi's Avatar
At first iwas thinking wth, but with the explination it helped a lot. Thanks
hehe i should get better pics but seriously, turbo is fine and no oil burned.. no smoke...
think.. if the turbo is not draining then i would get smoke like hell and oil in my charge pipes, downpipe and lower oil level... eventually the turbo will die.. obviously nothing has happened so it works... i drive my car hard.... like boosting 50 times a day..
Old Sep 27, 2003 | 08:25 PM
Smashback's Avatar
Yeah, well, not really. Your turbo fill with oil at over 30 PSI typically, and drains at 0 PSI. Thing is, it will back up into A before spilling much into B, and that's what you don't want. Once it backs up into A, it leaks past the seals and puff puff puff....hello, how much do you guys charge to rebuild a turbo?
You want the oil to be consinuosly able to drip drain from the turbo without having to be pushed out. If it's getting pushed that means you're building pressure, which is no good.
Old Sep 27, 2003 | 08:36 PM
Flamenco-T's Avatar
stan
cameron4776
Mar 15, 2008 06:15 AM
elcangripapi
Dec 20, 2006 04:17 PM
elcangripapi
Dec 20, 2006 04:16 PM
the.hamburglar
Jul 11, 2005 06:50 PM
