Installing Spearco FMIC today... will I notice a difference?
Now I have a starion IC, and I got my new Spearco 26x6x3 FMIC in the mail today and am going to install it later. Can I expect any changes??? Thanks in advance
New User
Re: Installing Spearco FMIC today... will I notice a difference? (Civic@7psi)
Since your old one was pretty small i bet it got heatsoaked during hot days. Your car was probably less peppier.
With a larger intercooler it wont be as bad and when you are cruising at night it should be even better.
gl with your setup
gl with your setup
i think that the starion ic was good enough for your setup because your not pushing mad power out. But at least it looks better and flows a little better.
Re: Installing Spearco FMIC today... will I notice a difference? (InTeGrA B18b1)
it may reduce boost response a little because there is more air volume that needs to be pressurized before it gets into the head.
Or you might not be able to tell. I went from 4 feet of charge piping w/ no IC to a 26x6x2.25" front mount with 6 feet of pipe. I turned up the boost 2 psi when i put the IC on and did not mind the slight lag at all. Do you expect you'll be able to turn the boost up?
beepy
07-31-2005 12:43 AM
dnbruut
02-28-2005 02:06 PM
igo4bmx
07-13-2003 09:50 PM
