High miles engine + Turbo
Old Sep 25, 2003 | 05:58 PM
Del_Slowest's Avatar
Default High miles engine + Turbo
Have a question about my honda del sol si. It has a D16z6 with 140,000 miles on it. Runs like a champ all the way to redline still but i was going to put a turbo on it this weekend. It's a greddy turbo with only 5.5 psi of boost. I don't leak any oil or anything right now and it idles perfect. Just wanting some insight on whether or not to put the turbo on at all. I'm afraid i might ruin my piston rings with the turbo and end up messing up the engine all together. I'll have an apexi vfac hack on it also with 450cc dsm injectors. Please reply.....
Modified by Del_Slowest at 3:35 PM 10/1/2003
Old Sep 25, 2003 | 06:10 PM
p0gi's Avatar
Default Re: High miles engine + Turbo (Del_Slowest)
Do it, I put a turbo on my wifes car at 145,000 and it now has 185,000 and runs like a champ
Old Sep 25, 2003 | 06:21 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest &raquo;</TD></TR><TR><TD CLASS="quote">money i don't have.</TD></TR></TABLE>
if thats the case.. don't boost your motor, although they're cheap to replace, but if you can't spend money on that.. don't mess with it.. you gotta be prepaired to shell out $$$ for rebuild/repairs and maintanance.
Old Sep 25, 2003 | 07:06 PM
Default Re: High miles engine + Turbo (vtec.dc2)
i've searched this forum for 45 min looking for the compression numbers for a D16Z6. i know it's like 9.1 to 1 or something but whats with people posting numbers like 220 or 250 and stuff for their B series motors. I know i'm stupid but i'm sure other people out there are wondering the same thing. Just to let you know, i did try and find these numbers out for myself but now my eyes are hurting from searching
Old Oct 1, 2003 | 02:35 PM
anyone?
Old Oct 1, 2003 | 02:39 PM
R6Elmo's Avatar
i have zero idea what you are asking in your other post. I'm not sure if the d-series motor is that low of a compression or not. I would think a little bit higher And yes, people do post numbers for b-series motors b/c they are pretty popular to boost.
Old Oct 1, 2003 | 02:42 PM
Ri5e's Avatar
Default Re: High miles engine + Turbo (R6Elmo)
If it has 180 PSI or more compression, then go for it
ahobbs's Avatar
HELLO,GOOD MORNIN'
My buddy had 210,000 on his before it blew. It blew the day he got his hondata tuned......bad tuner. Never had a problem before.....and it was FMU.
Old Oct 1, 2003 | 02:51 PM
nevin's Avatar
you should be ok
Old Oct 1, 2003 | 03:01 PM
Bailhatch's Avatar
Default Re: (nevin)
Even if you don't have lots of money that motor is really cheap and easy to swap in and out. I just boosted a d16z6 w/ 130k and have put over 3 thousand on it with no problems. I run 8.5psi in 4th and 5th every day over and over. No problems except the clutch slipping in 5th every now and again.
I am useing a t25 so my 8.5psi might be like your 5 or something, i don't know how they compare as far as flow goes.
Old Oct 1, 2003 | 03:19 PM
ITSTOCK's Avatar
Default Re: (Bailhatch)
USDM ED9 on here ran 9psi on his d16a6 which had 220k + for over a year ( he also has crazy tuning skills ) so i say go for it!
Old Oct 1, 2003 | 06:48 PM
Default Re: (ITSTOCK)
thanks a lot guys. I have new confidence in the motor. I am gonna swap in 86-87 integra rods and bearings though b/c they hold up to 250hp compared to D16Z6's 200hp
rice a roni
Mar 27, 2006 07:26 PM
yusoslo
Mar 23, 2004 06:26 AM
LsTurbo91
May 2, 2002 05:17 AM
JV
Jan 23, 2002 01:23 PM
