running charge pipes (need to cut fender well)
okay, i need to cut through my drivers side fender well in order to run my piping. theres like one layer of metal, a space in between and then another layer of metal. what would be the best way to cut a hole through them? i already tried a metal hole cutter and because the surface is un even it did nothing but go crazy. i have been using a dremel, but i cut a 2 inch hole in like 15 minutes, is there a faster way? maybe a special bit?
Re: running charge pipes (mattcalica)
saw-zaw???
maybe a mini air saw???
hummer/ cut off wheel(air powered)
btw what kinda car is this that you need to cut this section out of your car??
Re: (quikB18B)
A hole saw in a drill should work best.. Sounds like you didn't get the pilot bit for it. Its probably too late now so try a jig saw They are like a sawz all but smaller and have a much thinner blade to make the circle.
trancedroller
04-17-2010 02:42 AM
4cefed
Welding / Fabrication
13
11-01-2006 01:18 PM
DJ_CARY
17
06-04-2005 01:06 PM
kim_2_da_chee
13
01-08-2003 12:39 AM
