Help with VAFC!
Old Sep 26, 2003 | 01:03 PM
xTuRboTeGgYx's Avatar
Default Help with VAFC!
Just got my VAFC installed in my '99 GSR and it's running hella rough at factory default settings.
Mods
-Drag 3 turbo kit (T3/T04E 57 trim 5lbs)
-MSD
-BBK 255 fuel pump
-Mugen re-map ecu
-No boost controler
-(STOCK INTERNALS)
It's gonna be a while till i dyno tune my car so please share VAFC settings if you have similar mods.
Old Sep 26, 2003 | 04:43 PM
ImAcracker's Avatar
Loved
By factory default setting do you mean 0% fuel trim through the whole RPM band?
Old Sep 27, 2003 | 09:51 AM
Default Re: (ImAcracker)
I'm not sure if the VAFC default settings is at 0% fuel trim. There's an initialize set up you do before starting the car but it doesn't say to adjust any aspects of fuel.
Still looking for VAFC settings, please share them if u have similar set up.
Old Sep 27, 2003 | 11:02 AM
15psi of fun's Avatar
Default Re: (xTuRboTeGgYx)
OK the first thing that scares me is the Mugen re-mapped ECU. Is it for all motor because if it is then the timing if going to be advanced pretty far. The next thing are you using bigger injectors you will need them to make the hack work and it sounds like that’s what you’re trying to do.
About the car running rough I would go back and make sure your settings are all the way they tell you to set before you even start the car. Then after you get that fixed find some 450 DSM injectors for like $50 and put them in. Then do a search there is about a million post with setting you can find on here, But let me say this even if you have the same set up as a friend I mean every thing is the same boost, motor, turbo kit, and stuff like that. The cars will still have different setting to make them run safe so be careful and have fun boosting after ever thing is fix that is.
Old Sep 27, 2003 | 11:24 AM
inspyral's Avatar
If you initialized it, then your car and sensor type settings are probably reset too. You need to set it to 6 in, 6 out with the arrow pointing up to the right sensor type, 4cyl car type.
Old Sep 27, 2003 | 11:38 AM
Default Re: (EFrollingout)
Thanks for the info.
Old Sep 30, 2003 | 10:36 AM
Does anyone know of any sites or threads that may offer VAFC settings for my car??? Or is anyone out there with same mods thats ok with sharing their settings??? Please help!
Old Sep 30, 2003 | 11:23 AM
VTC_CiViC's Avatar
Why don't you just set everything to zero and see how your car runs to make sure it's not the AFC?
Old Sep 30, 2003 | 01:45 PM
Default Re: (VTC_CiViC)
k i'll see if that will work....thnx
Old Sep 30, 2003 | 07:36 PM
InTeGrA B18b1's Avatar
look for teh dropshoptv site i dont remember the link but it is step by step in there
Old Sep 30, 2003 | 07:44 PM
ITSTOCK's Avatar
Default Re: (InTeGrA B18b1)
http://www.thedropshop.tv then go to tech
Old Sep 30, 2003 | 07:57 PM
xci_ed6's Avatar
Default Re: (ITSTOCK)
Okay, this sounds very bad. you need to screw around with the fuel trim and display settings of your V-AFC w/ the screen off. Re-read the directions, and memorize the menu flow chart. The V-AFC is very powerful, after all it can let you run 450s and boost on a Honda, but it can also FUBAR your bottom end.
-Dustin
Old Sep 30, 2003 | 09:07 PM
Mr.DC2TurBo's Avatar
Default Re: Help with VAFC! (xTuRboTeGgYx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xTuRboTeGgYx &raquo;</TD></TR><TR><TD CLASS="quote">Just got my VAFC installed in my '99 GSR and it's running hella rough at factory default settings.
Mods
-MSD
-BBK 255 fuel pump
-Mugen re-map ecu
-No boost controler
-(STOCK INTERNALS)
It's gonna be a while till i dyno tune my car so please share VAFC settings if you have similar mods.</TD></TR></TABLE>
I too have a chipped ecu. My settings are around -23% to -21% lo/hi. I really don't know why my readings are so hi compare to others around -36% across but it could be due to the chipped ecu. Let me know if yours idle around my setting or is mine the wierd ball.
Old Oct 1, 2003 | 05:45 PM
Default Re: Help with VAFC! (Mr.DC2TurBo)
Hey thnx for all the feeback. Yah so even with the AFC settings all at 0% and no adjustments my car is still running like crap. I'm thinking of disconnecting the plug that runs from the ecu to the AFC unit to run without it. That way i can determine if the problems with the AFC or a mechanical problem.......Do you think it's safe for me to just unplug and then drive like that??? Please reply, thnx.
Old Oct 1, 2003 | 06:00 PM
ross1459's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xTuRboTeGgYx &raquo;</TD></TR><TR><TD CLASS="quote">Hey thnx for all the feeback. Yah so even with the AFC settings all at 0% and no adjustments my car is still running like crap. I'm thinking of disconnecting the plug that runs from the ecu to the AFC unit to run without it. That way i can determine if the problems with the AFC or a mechanical problem.......Do you think it's safe for me to just unplug and then drive like that??? Please reply, thnx.</TD></TR></TABLE>
no. that will make your car run even worse and cause more problems because by doing so you will have completely disconnected the MAP sensor from the ECU. if you installed everything yourself and know what to do, you could try uninstalling the VAFC harness at the ECU.
1GPlusSH
Jan 27, 2007 11:49 AM
Jason kiDD
Mar 25, 2005 11:01 AM
Forgiveness
Jan 7, 2005 02:08 PM
EK9Blitz
Oct 3, 2002 10:52 PM
hondalawnmower
Oct 2, 2001 10:45 AM
