Head studs...ARP's Vs Stock
Old Sep 25, 2003 | 09:00 AM
*Boostwerks*'s Avatar
Default Head studs...ARP's Vs Stock
Ok...I'm going to call a couple of shops and see if I can find a Cometic gasket for my ZC in stock (they stoped making them). If not i'm just going to use the stock carbon gasket.
If I can find one, would I be fine just re-using the stock studs?
Or should I just shell out the $120 for some ARP's?
Thanks!
Old Sep 25, 2003 | 09:09 AM
PrecisionH23a's Avatar
Default Re: Head studs...ARP's Vs Stock (Bryson)
Technically you are not supposed to re-use head studs due to the bolt stretch that occurs in the bolt when torqued down. I would shell out the 120 for ARP's, and keep in mind they can be used time and time again
You can get away with using the stock ones if you HAVE to, but i wouldnt... especially on boosted cars.
Old Sep 25, 2003 | 09:10 AM
Default Re: Head studs...ARP's Vs Stock (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Technically you are not supposed to re-use head studs due to the bolt stretch that occurs in the bolt when torqued down. I would shell out the 120 for ARP's, and keep in mind they can be used time and time again
You can get away with using the stock ones if you HAVE to, but i wouldnt... especially on boosted cars.</TD></TR></TABLE>
that is precisely why I asked...I heard of that, but just had to confirm!
Thanks man. Oh and props on the 400+ dyno run! I got your vid...
Old Sep 25, 2003 | 09:50 AM
ladysman's Avatar
Bryson,
Definitely upgrade to ARP's. Well worth the money. Good luck.
germ49
Jan 21, 2013 05:34 AM
cafine
Jun 2, 2010 09:16 PM
bow tie
Nov 15, 2008 05:11 PM
2.2EL
Dec 4, 2003 07:59 AM
AdamITR
Aug 13, 2002 10:59 AM
