Dyno Graphs
B16 block
JE pistons
Eagle rods
stock head
Drag kit
550cc
15psi
300ft lbs of torque on a b16 biatches... Not quite sure why it says ls VTEC cause its def a b16. I built the engine myself. Oh yeah and i gotta get a bigger wastegate spring. As you can see it falling off on the end.
JE pistons
Eagle rods
stock head
Drag kit
550cc
15psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">haha, when your power peaks at 5800 on a b16 you know you've got problems!</TD></TR></TABLE>
haha just saw that and then read his W/G problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">why would it require a bigger wastegate? or does he mean a bigger spring for more boost?</TD></TR></TABLE>
Yeah the waste gate is opening at the end due to the spring in the wastegate. I only have a 6lbs spring. Anyone know where a good place to pick one up is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">What crankshaft?</TD></TR></TABLE>
Stock b16 stroke. Its a torque monster of a b16 eh?
you put a bigger wastegate spring on that puppy and ur really gonna have a crazy power band... good luck getting that power to the streets... if you can get it to hook... thats gonna be nutz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16 matt »</TD></TR><TR><TD CLASS="quote">
small turbos do that
Natural Aspirations
53
Jun 12, 2006 12:48 PM
