Water Cooled Question !!
Old Sep 28, 2006 | 10:54 AM
9civichatch3's Avatar
NICE GUY
Default Water Cooled Question !!
I am putting a Garrett GT28RS a.k.a Disco Potato on my B16 and was wondering where is a good place to tap for water since it is oil and water cooled.
I have a couple of thought, but was wondering if you had any suggestions!! Thanks !!!!!!
Old Sep 28, 2006 | 11:33 AM
cypresscoupe's Avatar
bypass the throttle body coolant lines and run them to turbo
Old Sep 28, 2006 | 11:40 AM
LoseRPunKx182's Avatar
Default Re: (cypresscoupe)
throttle body
Old Sep 28, 2006 | 11:42 AM
NICE GUY
Kool, i was considering that. anyone else with other suggestions.
Old Sep 28, 2006 | 12:02 PM
b18BoostedDC2's Avatar
Default Re: (9civichatch3)
i had a fitting taped to the block drain bolt and one taped to the t-stat housing. its a lot more cleaner that way.
Old Sep 28, 2006 | 12:07 PM
abnaasefmb's Avatar
Default Re: (b18BoostedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18BoostedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i had a fitting taped to the block drain bolt and one taped to the t-stat housing. its a lot more cleaner that way.
that's a better way.
the best way is from the bottom of the radiator to the t-sata housing.
Old Sep 28, 2006 | 06:05 PM
NICE GUY
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">
the best way is from the bottom of the radiator to the t-sata housing.</TD></TR></TABLE>
i will keep it in mind, but I kind of like the throttle body idea
Old Sep 28, 2006 | 06:42 PM
riceball777's Avatar
Default Re: Water Cooled Question !! (9civichatch3)
i just run mine in line from the throttle body.
stock there is a coolent line from the throttle body to the intake manifold. i run it from the throttle body to the turbo and from the turbo to the intake manifold
Old Sep 28, 2006 | 07:29 PM
elements018's Avatar
yeha use the coolant line from the TB
Old Sep 29, 2006 | 09:14 AM
NICE GUY
Default Re: (elements018)
anyone else !!!!!
Old Sep 29, 2006 | 09:50 AM
sp00led's Avatar
I had an extra water port since the b18c1 block was obdI and had a factory oil cooler I decided not to use. We taped a hole in the bottom of my radiator for the return line.
Old Sep 30, 2006 | 10:21 AM
Mr HYDE's Avatar
Default Re: (sp00led)
you are sayign to run it from the throttle body. i got a gsr and my coolant line comes from the water inlet port from the rad then to the FICV then a line to the IAC can u bypass that? arent u suppose to run coolant through those?. i also have on my thermo houseing a block off cooling port. can i run one line from the water inlet and bypass the ficv and iac and then run the second line to the extra port ihave ont he thermo houseing?
Old Oct 1, 2006 | 07:30 AM
NICE GUY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 &raquo;</TD></TR><TR><TD CLASS="quote">anyone else !!!!!</TD></TR></TABLE>
Old Oct 1, 2006 | 07:45 AM
coneheadsracing's Avatar
I took out my heater core, and box and all that great stuff. So i just use the two lines that use to go to my heater core.
Old Oct 1, 2006 | 07:58 AM
Dollar_bill
Guest
Posts: n/a
Default Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">I took out my heater core, and box and all that great stuff. So i just use the two lines that use to go to my heater core.</TD></TR></TABLE>
Emmmm!,never thought of that.Good stuff.
Old Oct 1, 2006 | 09:06 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">We taped a hole in the bottom of my radiator for the return line. </TD></TR></TABLE>
The bottom of the rad would be the feed not return.
Old Oct 2, 2006 | 06:14 AM
NICE GUY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elements018 &raquo;</TD></TR><TR><TD CLASS="quote">yeha use the coolant line from the TB</TD></TR></TABLE>
Modified by 9civichatch3 at 12:18 PM 10/26/2006
Old Oct 26, 2006 | 09:46 AM
NICE GUY
anyone else have any input !!!!!
Old Oct 26, 2006 | 10:38 AM
Soccerking3000's Avatar
the front waterjacket drain bolt and t-stat housing IMO is the best and cleanest way to go hands down, dont just do the t/b cause its the easiest...
Old Oct 26, 2006 | 12:23 PM
slow poke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have any input !!!!!</TD></TR></TABLE>
Come on dude, stop being so dam lazy and search. Its only been covered on every site i know of a thousand times. Its not like you have something that no one has done before.
Old Oct 26, 2006 | 12:49 PM
NICE GUY
Default Re: (slow poke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
Come on dude, stop being so dam lazy and search. Its only been covered on every site i know of a thousand times. Its not like you have something that no one has done before.</TD></TR></TABLE>
thanks for your input !!!! anyone else tried something different ?
Old Oct 26, 2006 | 01:34 PM
chasemyhonda's Avatar
B A N N E D
Why not just get a aluminum radiator for a Automatic Tranny.. they have 2 lines on the bottom for the tranny Cooler.
Old Oct 26, 2006 | 02:09 PM
96 GSR-T's Avatar
Default Re: (blindingxenon)
Might be a dumb question, but what is this port right here?
Old Oct 26, 2006 | 02:26 PM
B A N N E D
that would be the bleeder valve.
Old Oct 26, 2006 | 04:07 PM
96 GSR-T's Avatar
Can that be tapped? I also have an OBD1 block, I have to look for the spot mentioned above tomorrow.
