MBC question..
Old Sep 25, 2006 | 10:17 PM
shanepa2001's Avatar
Default MBC question..
is there a way to use a MBC to turn down the boost level instead of up? or to adjust a 1g wastegate to do the same because i looked on shop key pro and it didnt say anything about adjusting it, just replacing..
Old Sep 25, 2006 | 10:34 PM
Default Re: MBC question.. (shanepa2001)
come on some one knows this
Old Sep 25, 2006 | 10:46 PM
inspyral's Avatar
You can only use a boost controller to raise the boost level above whatever your wastegate puts out. Some internal wastegates have an adjustable rod that lets you adjust them to a certain degree, but you aren't going to be able to lower the boost level significantly by doing so. You would either need to swap to a different actuator that opens at a lower boost level, or weld your flapper shut and convert to an external gate.
b20vtech
Jan 24, 2008 05:55 PM
motormike40
Jan 3, 2007 02:35 AM
killa_lude
Oct 4, 2003 04:56 PM
Tru Dynamix
Sep 14, 2002 03:58 PM
BigDaddyRich
Aug 30, 2002 05:34 AM
