Posssible to bore exhaust housing?!?!
well im not sure if this is a stupid question or not but ive been searching for an exhaust housing for a while and i cant seem to find the right a/r with a p-trim.
so my question is..."Is it possible to bore out a smaller trim housing to make it fit a larger trim wheel???
No flaming please...i am very serious about this question because i am tired of searching for a housing that is just either too outrageous of a price or is on back order til who knows when
Re: Posssible to bore exhaust housing?!?! (DRAGLS)
Yes Full-Races T3/T67 HO uses this method. They put the T4 P trim wheel inside the T3 exhaust housing. It works very well. I have that Turbo on my car and love it
Re: Posssible to bore exhaust housing?!?! (BoostedEG6)
anyone know the process of how this is done??? or better yet if there is anyone local that might be able to do this for me
Re: Posssible to bore exhaust housing?!?! (curiousgpnoy)
you have to take them the exhaust housing and the exhaust wheel that’s going in so they can machine it to fit and have to proper clearance’s...... someone local to you might be able to do it but you would have to check with them to see if they have the proper machines and so on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curiousgpnoy »</TD></TR><TR><TD CLASS="quote">anyone know the process of how this is done??? or better yet if there is anyone local that might be able to do this for me </TD></TR></TABLE>
Majestic turbo at Irving.
They do that on my exhaust housing.
Re: Posssible to bore exhaust housing?!?! (dutchman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dutchman5 »</TD></TR><TR><TD CLASS="quote">
They do that on my exhaust housing. </TD></TR></TABLE>
you wouldnt happened to know how much they charge and what turnaround timewise is would you???
Re: Posssible to bore exhaust housing?!?! (tony1)
would a .50 a/r be okay for a P trim wheel?...i was realll lookin for like a .58 but i cant find any of those either
I would never go that small with that big of a wheel. That's why you can't find anything. The wheel flows so much more than that housing will, that it's pointless. Even a .68 housing is small for a P trim wheel. Why not use a smaller turbo if you need it to spool quicker?
just talked to the guy from majestic and got some interesting infomation...kinda made me rethink things bout using this turbo...guess im back waiting again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curiousgpnoy »</TD></TR><TR><TD CLASS="quote">would a .50 a/r be okay for a P trim wheel?...i was realll lookin for like a .58 but i cant find any of those either</TD></TR></TABLE>
.50 A/R is the A/R ratio of a TO4E compressor cover, I have never heard of a .50 A/R turbine housing, unless it's some akward diesel thing. A .58 A/R housing is a T4 turbine housing, and turbonetics sells .58 A/R P-trim turbine housings off the shelf. Don't mix up compressor and turbine A/R ratios, because they don't have anything to do with each other, and compressor A/R ratio has a much smaller impact on performance than turbine A/R does.
