Tuning for spool
Old Oct 1, 2006 | 02:12 PM
Jockobo's Avatar
Default Tuning for spool
any tips/tricks to get the turbo to spool a little faster?
Old Oct 1, 2006 | 02:31 PM
adseguy's Avatar
Default Re: Tuning for spool (Jockobo)
Timing and fuel...make them a little more aggressive instead of the standard 12.0:1 AF and xx timing. It's just tuning
Old Oct 1, 2006 | 02:35 PM
Tornadom's Avatar
Those are the only ways that I've heard of. Unless of course you go back to selecting a manifold, and turbo. Once you have made your selection, it is going to mostly be found in the tuning.
Old Oct 1, 2006 | 04:05 PM
kraig8's Avatar
also cam timing will help a little.
Old Oct 1, 2006 | 04:44 PM
eg:R's Avatar
displacement and ballbearing turbo
Old Oct 1, 2006 | 06:09 PM
boostd92's Avatar
Cam timing is HUGE... get at least an adjustable exhaust cam gear.
We took a TD06-20G MR2 turbo with the cams degreed and it made 200ft/lbs by 3500rpm. With 7 degree exhaust cam change it made the same 200ft/lbs at 2850.... your torque will drop off up top by doing this, but for a daily driver that doesn't see redline much, it's a huge seat-of-the-pants adjustment.
Old Oct 2, 2006 | 09:37 AM
Jockobo's Avatar
Default Re: (boostd92)
the cam gear thing works pretty good probably go back to that and lower the rev limit. messing with all the fuel and timing just doesnt seem to make a noticable difference. dunno
turbomaniac
Oct 11, 2017 05:19 AM
mountainrich
Classic Hondas
Jul 12, 2009 05:24 PM
cliff666
Apr 18, 2006 11:07 PM
hondafan62269
Jan 7, 2005 09:34 PM
Civic_95_Si
Oct 24, 2002 01:09 PM
